June 18, 2024, 03:43:34 PM
Need Help RE: Potentionmeters (pots) for Dean Markley DMC-80 amplifier
Started by 1HoneyNut, March 16, 2011, 06:58:56 PM
1HoneyNut
Greetings.
I new to all this and some help. I need to replace the vol, reverb and bass potentionmenters in a Dean Markley DCM-80 amp. However, parts are no longer available  i've been told. Any suggestions on comprable replacement pots? I have been told that the reverb pot is 10k linear and that the vol. and bass pots are 250k audio taper. Does anyone know if this is correct?
I guess if I can't actual parts my only option is to get comprable pots that fit the chassis and wirre them to the board... does that make sense?
Frustrated but hopefull,
1HoneyNut]
I have pasted below a picture of the potentionmeter.(see below)
DCM80
Clean
Volume= 250K A
Dirty
Gain= 1M A
Level= 10K B
Shared
Treble=250K B
Bass= 250K A
Mid= 10K B
Reverb= 10K B
You can use any pot, same size, they might be 16mm (small) or 25mm (large) body.
Suppose they have PCB mount legs; post a couple pictures.
guitarkitbuilder
HoneyNut, I'm curious about why you are replacing those three potentiometers?
Quote from: guitarkitbuilder on March 17, 2011, 09:23:23 AM
Me too.  While they might be worn out it is quite possible that just cleaning them might fix any issues you are having with them.
1HoneyNut
Simple, I was cleaning the pots, spraying them with electrical contact cleaner and when I tried to pull the knobs off ...the shafts came out with the knobs. Evidently they had either been glued on or were just old. In my inexperience I just thought they were diferents kinds of knobs.  My bad!Now I am screwed so I've been trying to replace them with much difficulty.
