May 25, 2024, 08:09:55 PM
Fet version of ENGL530 MOD2
Started by KMG, January 16, 2011, 02:47:31 PM
KMG
Project files
Controls
Reamping samples.
Tone controls at preamp in middle position, "Presence" and "Depth" at PA also in middle position.
Digits after channel name represents "Gain" setting.
http://milas.spb.ru/~kmg/files/projects/Engl530/fet/reamp/5W4x12/
Recording path: E-MU Tracker Pre->Fet Engl->Fet PA 5W->Bull 412V+L(4x12)->Sennheiser e906->E-MU Tracker Pre
Reamping samples through Speaker simulator V30 preamp output.
Tone controls at preamp in middle position.
http://milas.spb.ru/~kmg/files/projects/Engl530/fet/reamp/SIM_V30/
Recording path:
For files without "R" in name:
E-MU Tracker Pre->Fet Engl->Speaker simulator V30->E-MU Tracker Pre
For files with "R" in name additionally through Digital reverb engine AL3201 with dry/wet mix 50/50:
E-MU Tracker Pre->Fet Engl->Speaker simulator V30->Digital reverb engine AL3201->E-MU Tracker Pre
crane
Really cool projects (this and jcm800)
The only thing that worries me is it's costs.
Looks like at such high voltage these projects could cost close to real tube versions...
Dear KMG, I must congratulate you on your impressive work.  :tu:
KMG
QuoteLooks like at such high voltage these projects could cost close to real tube versions...
But the sound is also close to tube prototypes, especially while live playing. The main advantage of fet versions is their reliability & long time sound stability (no effect of emission loss).
During the "blind" tests guitarists usually say "I can`t tell what is the specific amplifier, but certainly, tube one".
DJPhil
Quote from: KMG on January 18, 2011, 07:05:11 AM
Yep, this is how I read these two projects. Lot's of care and testing resulting in a design that's a very close (or better) match for tube characteristics, but with all the durability benefits that come with solid state. It should sound the same from day one until the electrolytic caps leak (figure twenty years with good caps), barring damage or bad luck with one of the semiconductors. The FETs won't age, degrade (enough to matter), and require replacement like tubes would. Definitely an advanced project, but a real masterpiece.
crane
I was also wondering if KMG would be so nice and post some more info about winding those nice output trafos for his FET power amps...
KMG
Quote from: KMG on June 20, 2011, 09:05:27 AM
Mix sample: FET Engl + 5W FET PA + 4x12 cabinet
http://milas.spb.ru/~kmg/files/projects/Engl530/fet/reamp/5W4x12/530c1.MP3
Excellent clip as always KMG, sounds great.  What type of guitar and pickups were used in this recording?
KMG
QuoteWhat type of guitar and pickups were used in this recording?
It`s reamp of these DI samples
http://milas.spb.ru/~kmg/files/distr/DI%20Samles/Metaltastic%20HD%20DI%27s/
As know someone post on forum part of DI`s by this group
http://www.youtube.com/watch?v=NR7dG_m3MsI
