June 16, 2024, 06:06:36 AM
cr 112 shorting out
Started by clamup1, December 16, 2010, 05:15:59 PM
clamup1
need to get a bigger power transformer?
i think that one of the original TIPs was flipped over and screwed to the heat sink. (i had to unscrew it to read it) but im not sure. i didnt take pics before i tore it apart.
i think im gonna park this thing for a while, this whole project has ticked me off
clamup1
hey guys, the 127 was in backwards. now i need to find a piece of steel to attach the green wire to. i almost burned a hole in the carpet.
its kind of dissapointing that i cant make this a 212. ill save the other speaker for another amp i guess.
thanks for your help
bry melvin
actually you CAN make this a 2 12... Use something like Weber or Jensen mod low wattage 12s rated at 16 ohms in parallel
...you could also use 4 ohm speakers in series
just don;t use high wattage speakers...jensen mod 12-35s 16 ohm will probably work well.
however I think you'd be happier with the sound of something like a pair of weber 10F100t's  10" 15 watt speakers 16 ohm
but much more expensive.
You could probably get adequate volume out of a pair of Celestion Rocket 50s at 16 ohm too if you could find them.
clamup1
i bought 2 Celestion Red white and blues. 8 Ohm. i thought this amp had a higher wattage than 20. oh well.
wow the webers are built to order. cool
im not getting any sound so i think i have some trannies to fix.
Quote from: clamup1 on December 30, 2010, 10:00:02 AM
You could always run those two speakers in series and have it at 16 ohms.
clamup1
#35
ive got them run in parallel. cool now i have to figure out whats blown.
bry melvin
looks like parrallel there series would be something like :   amp output+ ->+speaker1- -> +speaker2 - -> back to amp
Quote from: clamup1 on December 30, 2010, 06:16:08 PM
I thought it wouldn't run at 4 ohms....which is what you'd have running them in parallel.
Parallel means that the + on each speaker is hooked to the + on the amp and the - on each speaker is hooked to the - on the amp.
Series means you have the + on speaker #1 hooked to the + on the amp, the - on speaker #1 hooked to the + on speaker #2 and the - on speaker #2 hooked to the - on the amp.
