April 23, 2024, 10:29:59 AM
Heatsinks for your poweramp
Started by joecool85, April 05, 2006, 07:37:26 PM
tonyharker
The LM386 is not an op amp but a power amp, albeit low power.  It could be getting hot because it it is oscillating. It should be cool if it is idling ie not passing a signal.
The LM386 is Not simply an opamp.
It is a power amplifier in it's own right.
The quiescent current with a 12Vdc supply is in the milliwatts.
So that wont make you say ouch.
The power dissipation of the package is 500 milliwatts (1/2 watt).
Again, no need for a heatsink.
If the device got that hot, it is hooked up wrong.
Most probably it is now bad.
flester
Quote from: Jazz P Bass on December 10, 2017, 01:55:41 PM
Thanks. Almost certainly was mis-wired but have sorted it out and runs fine on the breadboard and no longer gets hot. Seems to still work but I have spares anyway
Sent from my SM-G935F using Tapatalk
Those are nice Ic's.
Good to know that they are robust enough to survive being 'hooked up wrong'.
Any idea what mistake you made?
GB
Hi Guys... notwithstanding the (very valid) point about them failing... Cooling Fans can be very effective... potentially reducing the size of a given heatsink by 50% - or more.
Attached is a pic of a 100 watt with a relatively small heatsink - but with two 40mm fans directed down the cooling fins. The amp runs of a nominal 50 volt supply so these are two 24 volt DC units - with a little bit of additional circuitry to ensure that the voltage is equally distributed between them.
Bottom line it works very well.
PS. I have contemplated adding some sort of thermal protection (fuse or breaker) as a last line of protection - but haven't got that far yet.
GB
mandu
Year 2001 application note from ON semi regarding mounting considerations for power semiconductors. Regards.
JonnyDeth
I have a decent sized collection of heat sinks, but what I pulled out of my Beowolf projector that some criminal destroyed was a rather startling piece of salvage. It has a "heat pipe" too big to even adapt over to a CPU!
This for people that don't know, is a water cooled heat sink that's passive. The internal chambers and ducting use infinite distillation so the coolant rises to the outermost pipes from the core point where it's encountering the source of heat and was vaporized, is cooled quickly through the thermal process moving air, recondenses and runs back down to the core of the system again and whatever the device is that's generating all the heat.
The one out of that projector is absolutely massive so when I get a project that calls for it, I'm going to be all excited I discovered and saved it lol.
