June 16, 2024, 06:20:04 AM
Trying to fix Yorkville 200B Amp
Started by Soupaman91, August 18, 2010, 03:27:34 PM
Soupaman91
Hello everyone, I am new here and I am trying to fix a problem with my bass amp.
The amp is a Yorkville 200B. The problem is, when I plug everything in and turn it on the amp works fine, but after a short period of time (say 1 minute of playing) it starts to crackle/buzz that overpowers the actual notes. If don't let up and keep playing the sound crackling will build and build (think a crescendo) and then it cuts out almost entirely. I've concluded that it's not the bass or the chord as both work fine with other amps/guitars, so it has to be the amp.
Anyway, I think it's the actual input on the amp. I say this because if I apply pressure upwards on the chord where it enters the input (for example using my knee) it works fine.
Any ideas on how to fix the problem?
I opened it up last night, here are some pictures of insides:
Close up on the area around the input (the big black thing on the far right is the input):
http://remenaz.110mb.com/bass_amp/bass_amp_close_1.jpg
Overview:
http://remenaz.110mb.com/bass_amp/bass_amp_1.jpg
Thanks in advance for any help
Well, both pages missing ...
Anyway, you probably have either: cracked solder or cracked tracks where the jack meets the board or very close by, or the jack itself is bad/worn/bent.
Put on your best glasses, use good light and take a good look therte.
Repost your close-up pictures.
Soupaman91
Ok, look under that board, where the jack is soldered.
Resolder all pads, using a good, clean, hot, soldering iron and *a little* of good quality solder.
