May 23, 2024, 07:50:29 AM
yamaha hundred410
Started by alfredomatta, June 14, 2010, 11:25:51 PM
alfredomatta
hey everyone.. i have a yamaha hundred410 that i got second hand for pretty cheap and a princeton 65 solid state combo that i really really like..
i like the yamaha's sound but it feels like it needs a bit more headroom.. would replacing the speakers actually fix that, or is that all about the actual amplifier??
thanks in advance..
The original speakers are *very* good.  :tu:
alfredomatta
i agree.. they sound good and considering what i paid, it was definitely a steal..
i just want it to sound more like the fender.. i know different amp are going to sound, well, different.. but i wanted to see if it was at all possible..
thanks
Well possible,, IF you plug the *princeton* into the 4 x10 speakers :tu:
alfredomatta
would that be by plugging the yamaha to the princeton's effect loop out?? or would this have to be done by wiring them to the princeton amp?
Quote from: alfredomatta on June 15, 2010, 11:00:14 AM
No no no,,, Whoops sorry :-[
I mean the *Speaker out* on Princeton Driving the 4 speakers in the Yamaha.
Connect The princeton *speaker output* to the speakers in the *Yamaha box*.
*****I'm assuming you understand that you *NEVER* join 2 Amps together at the speaker end?*****
Without the amps in front of me I don't know if it's straight foward so if you are not sure don't mess with it.
alfredomatta
i see.. well the princeton does not have a "line out" or "speaker out" jack.. it only has the effects send and return.. i have tried hooking up the yamaha to the send jack on the princeton but it seems like the signal loses a lot of power by doing so.. i have to turn the volume up on the yamaha way higher than i usually would if i had the guitar plugged straight into it..
Play it safe and leave it alone.
I consider the Yamaha a higher grade amplifier compared to the Princeton, although it does not have good distortion; the easiest problem in the world to solve.
alfredomatta,
                  Yep JMF is right, no speaker out,,, then scap it till you learn more. :tu:
alfredomatta
