Tubes do not warm up. No sound out of amp.
Started by mexidan, May 17, 2010, 08:58:31 PM
QuoteI did check them
And what was the result? You tell us half the story :lmao:
Seriously, do as suggested above, with your meter on 20VAC check if you have 6.3VAC from pins 4+5 (they are usually united) to pin 9, and probably 12V DC from pins 4 to 5 in the first triodes.
Usual problem with *all* Bugeras is poor internal connectors , best is to pull them and solder wires straight to PCB pads.
JacksenC
Quote from: J M Fahey on November 10, 2010, 09:24:31 AM
:lmao:
I'm sorry
I was busy  :mobile
oh it's pins 4+5..my bad
Yesterday I checked the 2 + 7 pin from power tube slot
the needle from my multitester didn't move
ok then i'll check them tonight   :)
