April 25, 2024, 09:16:16 PM
fast peak limiter
Started by el mo, May 10, 2006, 07:37:07 PM
el mo
hi,
i suppose that many of you have seen this limiter design  http://sound.westhost.com/project67.htm  - does
anybody have any experience with this circuit?
thanks in advance
el mo.
RDV
What's the application?
RDV
el mo
aah, yes the application would be good to know. in this case it's a limiter in front of a PA ( probably tda 2030) as i'm planning to build a small practice amp.
the preamp is going to be something with 2 jfet- stages with moderate gain.
what i found interesting was that the article mentions methods of controling harmonic distortion in that type
of circuit  ;) -so i  wonder if someone has explored that before?
RDV
I believe this would be a good limiter between a preamp and an amp however it would be nice to be able to adjust the maximum output voltage by a pot or something so you could set it just below the point that a chipamp clips.
RDV
el mo
hi,
using a pot or a voltage divider would be very nice for sure :)  if you can't see anything that makes this thing completely unuseable for guitar i'll just try it out when have some free time.
