frankenstein idea
Started by dr_funkenstein, January 25, 2009, 07:59:39 PM
dr_funkenstein
so i have thos old 1 watt tube amp that was converted from a little radio broadcaster/amp fromthe 50's.
now, can i use that as a preamp?
what if i wired the input jack from my orange 30 watt to the input of that, and the output of it to the input of my orange amp?
could this be a winning idea?
pelanj
You can do that, but you have to run the power amp into an appropriate load (eg. 8ohm resistor) and then make a voltage divider to bring the signal to the right level. The same approach worked for me with a 15 tube head.
