yamaha g100 1x12 version 3, amp issue - no sound (sometimes)
Started by mentalmidget, September 22, 2026, 09:20:51 PM
You have not mentioned that you soldered the failed joint?
SO,,,
If the solder joint was loose as you noted and you have NOT re-flowed that joint, then it only takes a bump and the amp will fail again.
To fix the issue you will need to remove the whole PCB to access the solder side and re-flow the failed solder pad. If you don't feel confident in doing the above then you will need to take it to a repair shop as it's a tricky job.
Quote from: mentalmidget on October 04, 2026, 08:14:14 PMmy question is, could a bad relay that doesnt engage cause the buildup of heat at the voltage regulator/resistor?
No, the heat is normal. Voltage is dumped at the resistor and regulator by converting it to heat.
More likely there is an issue if those parts do not get hot.
And all that heat shortens the capacitor lifespans.  So caps near hot spots like that often go bad before others in the unit that are not so close to heat sources.
mentalmidget
so again. the other day, the amp went silent for a couple minutes, then started working again. i checked the resistor, it was properly seated, wasn't loose. im starting to think it might be a relay issue?
saturated
I would look at IC 112 and IC 113 (upc7915a and upc7815a) but I don't see any voltages there on the schematic  :grr
Here in 1994
Quote from: mentalmidget on October 12, 2026, 08:14:38 AMim starting to think it might be a relay issue?
The relay is controlled by the protection circuit.  I told you in post #2 (and several other times) about a common fault in the relay circuit that causes your issue.  Why not try changing those caps?  I won't bother you in this thread again.
mentalmidget
sorry. i'm new to working on amps.. appreciate your help. ill take a look at the caps. thanks.
