Been messing with tube board of my ADA MP-1 preamp: big discovery!
Started by Kaz Kylheku, July 17, 2026, 07:18:38 PM
Kaz Kylheku
For years I had not been entirely satisfied with my tone and have done various mods, all of which led to nice improvements.
Finally, some fourteen years after getting that MP-1, I attacked the dreaded tube board. So far, I've been zapped twice.
I did a full filter cap job (tube board, main board).  I tweaked the cathode bypass on V1A from 33 uF to 0.68 uF (tantalum).   V1B from 33 uF to 10 uF.  Replaced all other electrolytics on the tube board. At that point, I was no longer hearing differences nor expecting to.
And then ... I replaced the four forty-year-old 1N4007 recitifier diodes on the tube board with UF4007 ultra fast recovery ones. I was not expecting anything; maybe to hear a difference in the level or profile of noise when gains are cranked. But, holy mother of god, that change was the money! The magic mojo suddenly descended into the preamp and declared residence. The diffuse fuzziness causing poor note definition toward the bass end was suddenly gone.
I have a mod whereby I can switch the OD1 drive circuit's filter between 1.6 kHz, 2.2 kHz (stock) and 3.4 kHz.   I mostly have been using 3.4 kHz. 1.6 kHz was way too tubby/flubby at high gains, but good for certain darker blues or classic rock type tones. After the diode replacement, I'm using 1.6 kHz all the time and enjoying it, instead of going "meh" after a minute. It is no longer flubby. It has the plump bass and rounded off top end, but the chugs have a clarity: like froth on top of a stout ale. Notes are clear. When I'm doing neoclassical, it faintly reminds me of old Symphony X, say.
Man, oh, man. Damned recto diodes in your tube circuit, who would have thought? Nobody ever seems to talk about those. It's always caps and tubes. If I had only clued into this over a decade ago ...
That 0.68uF bypass in V1A is great though; that's a keeper. The 10 uf versus original 33 uF on the second stage doesn't make much difference; the 6.8 nF coupler does all the bass cutting there; anything larger than 33 uF makes no difference; 10 uF just slightly cuts a tiny bit of bass. You do need one stage with a small valued bypass in a high gain amp or preamp. Everyone has that. Marshall, Soldano, Boogie, Engl, ... Ada did a weird thing there with all four bypasses in high gain mode being 33 uF, and the coupling capacitors not being very small either at 6.8 nF and that's why MP-1's are known for a kind of thick, woody tone that isn't that great at high gains. 0.68 uF on V1A and it's good. The cathode resistor is 1.1 k, whereas Marshall likes 2.7 against 0.68 uF, but that's not a big deal.
saturated
I looked at some pics of the device and wondered how the heck it could have tubes in it being so thin  xP
Further investigation afforded me some pics with the lid off  :tu:
It looks pretty intimidating  xP lots of integrated circuits and such but I did see some cool looking through hole stuff
That's cool you can notice the subtle changes consider yourself lucky that you can still hear  :lmao:
Consumed by negative voltage ⚡
Kaz Kylheku
Quote from: saturated on July 22, 2026, 05:11:09 PMhow the heck it could have tubes in it being so thin
Yeah, they nicely lie there sideways, near the left edge. There is plenty of room because 12AX7/ECC83 are basically tiny. The main board actually has a cutout. The tube board sits a little bit down inside this cutout, and there is a bit clearance in the cutout for the bottom-most components. The tubes footprints are placed slightly upward in the tube board. The main board is designed such that there isn't anything under the tubes and there are actually 9 holes in the epoxy in a 3x3 square under each tube.
The whole thing is a 100% through-hole thoroughbred.
Every integrated circuit you see is through-hole, just like every resistor, diode or cap. To work on the main board, you have to take the bottom panel off to get to the solder joints.
Glad you didn´t touch something you shouldn´t turning a nice experiment into a nightmare  :dbtu:
Kaz Kylheku
Quote from: J M Fahey on July 27, 2026, 01:37:57 AMGlad you didn´t touch something you shouldn´t turning a nice experiment into a nightmare
Oh, I got zapped like three times over the past several weeks. One time like 15 minutes after unplugging the thing. After being zapped, I got several sparks out of the caps with a screwdriver.
The new caps in the tube board hold. They can't discharge through the rectifier diodes back the transformer, and it seems the tubes quickly stop conducting when the heaters are off, leaving lot of charge on the table.
BTW, the tubes are not as under-heated in these MP1s as people think. Today I measured the DC voltage across the 3300 uF filter cap (recently replaced) on the transformer windings that supply the heater without regulation, as well as two 5V regulators for digital stuff and LEDs. Well that cap measured at 11.47V! Basically only 1V below the full 12AX7/ECC83 heater voltage.
The schematic only says "8V unregulated"; if that were literally true, the sound would be atrocious.
