Acoustic 220 PA questions
Started by gbono, January 12, 2011, 01:54:42 PM
gbono
I finally have this PA working again but have a question about the AGC circuit. Are Q1/2 some sort of detector used in the AGC loop? How does the AGC work in this design?
This amplifier just about puts out 18Vrms (@2.7 ohms) before the positive part of the input signal starts to degrade. I'm also only getting 60 V out of the secondary at 120 V on the mains. I'm going to assume this was typical ACC production control in 1977. :(
QuoteAre Q1/2 some sort of detector used in the AGC loop? How does the AGC work in this design?
QuoteNo, the detector is Q11; Q1/Q2 are the Fets that attenuate the input signal.
Then Acoustic had excellent production control, that's the correct secondary voltage.
QuoteThis amplifier just about puts out 18Vrms (@2.7 ohms) before the positive part of the input signal starts to degrade.
Increase the drive slightly until the other peak just starts to clip and re-measure.
Remember this a MI amplifier and max. power was specified at 10% distortion.
Anyway you measured 120W RMS into 2.7 ohms , probably will get around 160W into 2 ohms, not bad at all.
And when you measure as specified by Acoustic, you might get closer to 200W.
