Quote from: mentalmidget on October 12, 2026, 08:14:38 AMim starting to think it might be a relay issue?The relay is controlled by the protection circuit. I told you in post #2 (and several other times) about a common fault in the relay circuit that causes your issue. Why not try changing those caps? I won't bother you in this thread again.
Quote from: saturated on October 12, 2026, 08:35:29 PMOne think I noticed is there can be a plus and minus Vcc or just a ground and positive VccIf you use a single ended supply you have to use caps to block DC at inputs and outputs, as everything will run at 1/2 VCC.
