Solid State Amplifiers => Preamps and Effects => Topic started by: jammy5152 on June 27, 2018, 09:37:14 AM
Title: Chorus Pedal Help
Post by: jammy5152 on June 27, 2018, 09:37:14 AM
I have a chorus Pedal that I’m looking at and I need to repair it so a 9 volt battery will work in it...
It will work with a 9 volt power supply plug- in but NOT with a battery
I’m a newbie at this :dbtu:
Thanks for your help.....
Title: Re: Chorus Pedal Help
Post by: Jazz P Bass on June 27, 2018, 11:09:19 AM
Please supply the name of the pedal and the schematic.
Post by: phatt on June 28, 2018, 07:25:04 AM
The most likely culprit;
That external power socket has a switch inside which engages the battery circuit when external power plug is removed,, it maybe broken.
And check the battery snap connector,, the wires inside the snap cover can break.
Use a DMM to check for continuity of battery circuit.
Post by: jammy5152 on June 30, 2018, 06:08:45 PM
It’s a Digitech Hardwire...
