Solid State Amplifiers => Schematics and Layouts => Topic started by: mgcasella on June 14, 2010, 06:28:56 PM
Title: Randall T2 schematic! FIXED!
Post by: mgcasella on June 14, 2010, 06:28:56 PM
I had to buy it because I could not find it for free ANYWHERE!  So...here it is  :)
Title: Re: Randall T2 schematic!
Post by: rodriki1 on June 14, 2010, 07:10:42 PM
HEY FRIEND...
THE FILE IS EMPTY..
Post by: mgcasella on June 15, 2010, 02:25:32 AM
Hmmm... I can't seem to get it to attach.  I will keep the schematic forever so if this upload doesn't work then just pm me with your email.  I'll get it to you asap!   :tu:
Title: Re: Randall T2 schematic! FIXED!
Post by: J M Fahey on June 15, 2010, 11:29:54 AM
Thanks, MG, it's very kind of you posting it here.
Post by: mgcasella on June 15, 2010, 05:15:50 PM
Quote from: J M Fahey on June 15, 2010, 11:29:54 AM
No prob - you're very welcome!   :tu:
Post by: Pilot1 on June 16, 2010, 09:08:25 AM
Quote from: mgcasella on June 15, 2010, 02:25:32 AM...
Thanks for sharing
but
be carefull
do not clone as it is
the schematic contains some errors
I believe that Randall wanted to make some mess:
for example NE5532 opamps are connected with inverting inputs to the ground,
someone found more mistakes?
Pilot
Post by: mensur on June 16, 2010, 01:58:15 PM
The schematic is correct, overdrive channel is direct copy of Egnater TOL series amps/preamps.What OPamp, if you mean second half of DC servo, it must be, or it will oscillate.
Post by: teemuk on June 16, 2010, 02:42:10 PM
I think he refers to the OpAmps on what looks to be a cabinet sim circuit.
Post by: Pilot1 on June 17, 2010, 04:00:58 AM
Quote from: teemuk on June 16, 2010, 02:42:10 PM
Hi Teemuk
exactly
ic4ab, ic1ab, ic5b
page 9
"filtercabsim sheet 2/3"
P
Post by: J M Fahey on June 17, 2010, 08:59:29 AM
Hi Pilot, you are right.
Inverting and not inverting inputs are swapped.
Not only their pin number, which might be attributed to carelessness or thinking the board upside down, but the function too, which can't be forgiven.
Not the first time a factory schematic has errors.
They might be there on purpose to discourage the mindless "photocopier", probably not affect servicing, as a dead IC would simply be swapped for a new one, without much analysis or waste of time.
Post by: nickb on June 20, 2017, 11:53:59 AM
Sorry for the necrobump.
The posted schematic will not render correctly.  I guess it has become corrupted.  Can someone post a clean copy?
Thanks
Post by: g1 on June 20, 2017, 12:17:21 PM
This it nick?
http://music-electronics-forum.com/attachments/23399d1368613296-t2_schematic.pdf
Post by: g1 on June 21, 2017, 02:40:50 PM
And I will post it here anyway, just in case.  :)
