Solid State Amplifiers => The Newcomer's Forum => Topic started by: saturated on November 09, 2026, 11:11:50 PM
Title: Differential Day of Depletion
Post by: saturated on November 09, 2026, 11:11:50 PM
Gonna try to build this and perhaps have some fundamental principles become aware  xP
Here we go (shamelessly plagiarised)
We're off to a good start
Which means things should go downhill quickly  :lmao:
Why go downhill when you can jump 🦘 off a cliff ?  So here goes
-im guessing that ok yes it's gonna be a differential amplifier so it seems kind of silly (to me) to input signal to one side then (maybe) input on the other side and (possibly) see it inverted
Which is cool I presume when you are trying to amplify a difference to monitor two different signals but why have a differential amplifier in something like a guitar amplifier where there is ONE signal
Idk maybe they compare different stages to keep them in line it's probably complicated  :lmao:
Hmm time to look at some amplifier schematics that employ such configurations  :grr
Title: Re: Differential Day of Depletion
Post by: saturated on November 10, 2026, 12:44:19 AM
Moving right along I assembled this circuit and remembered Miss Wolfen has a new favorite spot
Oh well on with the show
The was an abundance of ample amplification available (I had it backwards measuring output on the left side is inverted)
Then when I took Vo on the other side it was in phase
Since I don't know anything I figured there would be NO output from the non-input side
Hopefully some things will start clicking if I take a look at some actual guitar amp schematics
