Solid State Amplifiers => Amplifier Discussion => Topic started by: TomCarlos on December 21, 2025, 03:07:00 PM
Title: amprx Brown Box
Post by: TomCarlos on December 21, 2025, 03:07:00 PM
My friend asked me if I or anyone have any experience with this device?
My concern is that while it might "change" the incoming AC voltage, I am wondering if it can handle a high current peak.  It is rated for 540W @ 120V AC, 5 amp. So it seems like its ok for lower power amps.
I guess anyone can use a Variac and Voltmeter to achieve the same results.  So this looks like a convenience item.
I guess the other thing is that do you really hear a difference if you reduce the voltage on an amp?
https://www.youtube.com/watch?v=-gaSeS6Nu8w
Any thoughts?
Title: Re: amprx Brown Box
Post by: g1 on December 22, 2025, 10:29:04 AM
I think it's primary purpose is to protect expensive vintage amps from modern higher line voltages.  Lots of older stuff was built for 115VAC, line voltage where I am is usually 124VAC.
https://www.brownbox.rocks/products/brownbox-by-amprx-a-stock
