Solid State Amplifiers => The Newcomer's Forum => Topic started by: saturated on June 28, 2025, 01:12:21 AM
Title: I just did some headbanging
Post by: saturated on June 28, 2025, 01:12:21 AM
So I was doing an experiment per textbook
Take a 2n3904 ground the base
Put +12 at the collector resistor
Put -12 at the emitter resistor
Ok that in itself was quite a task but I managed and no matter what kept getting a Ve of -3.7v
It took me a while to figure that if base was at ground then thats probably not correct.
So I reconnected configurations ad nauseum and kept getting the same thing  :grr
Meanwhile kept checking that VB = ground.
Finally I was like well hell why don't you check the transistor so I did a diode check with my multimeter and + on base to emitter was showing a one.   :loco
So I grabbed a new one and it showed about 0.67  xP
Ve with new one in circuit
Ve with old one in circuit
And the diagram
Now the "old" transistor is pretty new from mouser a year or two ago but..to be fair is has been subjected to some abuse like reverse biasing and stuff....
Anyhow I thought I was going crazy  :'(
Title: Re: I just did some headbanging
Post by: saturated on June 28, 2025, 01:41:35 AM
Tested by the atlas
 xP
