Everyone seems to think that they need more watts to get more volume. While it is true that more watts will be louder than less given the same speaker, it is also true that the speaker is more important than the watts in most cases.
For every 10db gain (double perceived volume) you need a 10x multiplication of wattage. So a 100watt amp is only twice as loud as a 10watt amp. The reason this doesn't normally seem so is that 10watt amps normally have poor spl rated speakers, making the 100watt amp sound more than double the volume. Playing through a better speaker will help increase your db rating, and hence your overall volume.
I've attached a chart to give you an idea of how an efficient speaker is louder than more watts on a less efficient speaker.
With this chart you can see that a 90db speaker on 100watts is less volume than a 102db speaker cab with only 10watts. Most inexpensive amps come with speakers of about 90-93db.
To keep up with an average drummer you will want about 110db. To reach this level you could use a 100watt amp with a single 90db speaker or you could run a small 10watt amplifier through a cab with rated 100db or better.
The calculation for total db is this:
{log (watts of amplifier) x 10} + speaker spl rating in db at 1w = total db output
Or if you want to figure out what db speaker (or cab) you need to hook into to get a certain desired db output:
Desired db output - {log (watts of amplifier) x 10} = Necessary speaker/cab db rating at 1w
Here is an excellent calculator for adding up speaker db and finding what the total output is: http://www.sengpielaudio.com/calculator-spl.htm
And thanks to Roly, another good table:
| Speaker sens. (1dB/W@1m) | Required power (watts) |
| 104db | 1 |
| 101db | 2 |
| 98db | 3 |
| 95db | 6 |
| 92db | 12 |
| 89db | 24 |
| 86db | 48 |
| 83db | 96 |
| 80db | 191 |
| 77db | 382 |
Listener range 8 feet, desired listener SPL 80dB, amp headroom 15dB
But for what I have seen, most likely, there will not be db marked on the speaker. Usually I see Ohm and Watts.
What can I do if I can just see the two information marked? Perhaps the size can help?
The datasheet sure helps. ;)
If the speaker was a "house brand" one pulled from a guitar amp, as a "Jaguar" from a Randall, a "Fender special design" or an unnamed one from a Crate or Peavey, etc., they are almost always an OEM Eminence; most probably available to the general public as one of the "Legends".
Generic "Celestion inside" boxes most often have "Rocket 50" , sometimes V60 or at best "Seventy 80", being the least expensive ones.
Beware, they all sound good, it's just that they were not "used by Hendrix"
You could possibly rig something up to do the measurements yourself. You can put a sine wave through your amp and hook up an oscilloscope across the speaker terminals. Then adjust the gain until you have one watt across the speaker. You might need to put a known resistance in series with the speaker to measure the current to help determine power since the exact impedance of your speaker at that frequency isn't going to be known (I guess you should use a 1 khz frequency for your test signal).
After knowing the power put through the speaker, you can then measure the dB spl, which I unfortunately am not to sure about how to do. Has anyone here made such measurements?
I bet someone could rig up an arduino board to both generate signals at a variety of frequencies and take measurements of the current through the speaker by measuring the voltage across the sampling resistor. And maybe even read the signal level from whatever microphone you use for db spl measuerments. Maybe after measuring all this, you can compare the impedance and frequency response curves with those from known eminance (or other manufacturer's) speakers to figure out which model was rebranded for your amp.
My little Dean Markley which is running at 20watts on a 92db speaker is pushing 105db or so. If I ran it through a 4×8 cab with four 93db speakers that would get me up to 112db – enough volume for me to do some small gigs with it. Although more likely I would get a Fender Frontman 65R as it pushes 111db stock on it's built in speaker, or 120db with a 4×10 cab loaded with 96db speakers. This would do small gigs on it's own and most larger ones simply by plugging in a 4×10 cab. To get the 120db needed for a larger venue with my Dean I would need to plug it into 3 cabinets of the 8×10 cab variety loaded with 96db speakers...you can see at this point more wattage is necessary. There is definitely a diminishing point and I would say that 4 speakers is it really. Maybe 8.
Thanks, now I get the general idea of it.
Sadly, I don't have instruments to do those testing. Perhaps I should buy the speaker with specification provided.
To measure at home, you need an amplifier (*any* amplifier), download a "Pink noise MP3" , there's a few around or, worst case, I send you a sample, and a SPL meter, there's a Radio Shack one which is very affordable. U$45 the analog one; U$49 the digital one.
It's available almost anywhere thanks to those guys who want to set perfectly their "5.1" home theater systems, maybe somebody you know has one you can borrow for an hour or two.
You play your pink noise into the speaker through the "line input/loop return/Pwr amp in" , straight into the power amp , not through the preamp, and set the volume so you send 2.83 Volts into an 8 ohm speaker, 2V into 4 or 4V into 16.
In all 3 cases you are sending a nominal 1 Watt to the speaker.
You put your meter at 1 Meter distance pointing at the speaker and take the reading.
*That* is the naked truth, forget Marketing embellished datasheets.
You'll be surprised !!!
That's what they mean when they say: "X" Db SPL at 1 Watt at 1 Meter.
Without an SPL meter you can't take a numeric reading, but still can compare speakers for your own use, just play your pink noise as before, set it to 2.83 V and switch between both speakers back and forth, let your ears be the judge.
You will not only hear "volume" differences, but "response" differences, no two speakers will sound alike (unless same brand, same model, and sometimes not even so).
Do the experiment, it's very useful and mind-opening.
A factor seldom taken into consideration is that with higher power available for less per watt, speaker elements have grown less efficient because they have to be designed to handle more power.
There are a couple ways to make a dynamic element more able to withstand higher power. You can increase the voice coil wire size, which adds mass which lowers efficiency.
You can make a speaker able to handle further excursions of the diaphragm which presents a problem. The suspension of the cone needs to be more compliant, to be able to move to greater extremes. The means the concentrically of the voice coil in the pole piece(the magnet gap into which the VC is placed) worsens. At any given instant the position of the center axis of the VC and the pole piece is less known, with more variability. To solve the resulting rubbing that can result from less precise VC placement during it greater excursion, the gap is made wider. That decreases flux concentration which reduces driver efficiency a great deal deal.
The suspension can be made stiffer instead of increasing the pole piece gap. That also increases efficiency.
High power speakers, as a general rule, are less efficient than speakers of the same size that are designed for less power so more power is needed for the same acoustic power coupled to the room.
An array of small, efficient speakers in appropriate cabinet at any mid point frequency will create more acoustic power per watt.
But guitars are not signal generators operating at a single frequency. The speaker/amp/guitar combination is interested in specific parts of the spectrum, not the full audio spectrum. Speaker specs such as sensitivity are general clues but since they are taken at a specified very easy to produce frequency, usually 1khz or 400hz, the spec does not tell you as much as you might want to know in predicting how loud a particular combination of cab/driver/amp will sound like.
Flat frequency response is not a major goal in guitar amps so cabinet tuning is usually not done, which can greatly influence speaker efficiency as a system. But the tone difference between cabinets becomes pretty dramatic when a driver is working into an restricted infinite baffle style cab, like open back combo's usually are.
The question is, what efficiency do you get get in the portion of the spectrum your music requires to produce the tone you want? The specs on a spec sheet for a raw driver tells very little about that. Almost any speaker can be made to sound like any other but not at the same efficiency. Compare the flat linear response from a tight pole piece system in a horn, such as the Klipshorn or even the Altec folded midrange horns, and their great efficiency to your current 200watt blaster master driver. 1 watt, through most of the audible spectrum will drive you out of the house, 60 watts fills auditoriums. But 100 watts would burn up their highly efficient drivers.
Guitarists can get a closer approximation of their desired tone character from speaker experiments than anything they can do with their amps. The harmonic spectra generated by a speaker in appropriate cab or baffle can be very muscial, particularly with tube amps because of the lack of damping tube amps with little or no negative feedback have to control the fidelity of the cone movement to the signal level. Solid state amps, usually have a high damping factor so control the absolute fidelity of cone position to signal instantaneous level much better. That means less distortion generated by the cab alone. That is great for "reproducing" sound but less desired in "creating" sound. More attention needs to be payed to the amp signal impressed on the speaker in solid state because of that great control of the sound produced than with a tube amp.
A tube amp might sound good in a particular style of play but not in another because the amp and speaker are pretty much free agents doing as they please despite the intent of the other. As a result of that fact, solid state is more versatile and can handle a wider range of material, but needs to take more responsibility for the resulting sound. There is a lot more potential, but underused, upside potential in good SS designs. Given that the speaker is less a free agent, not imparting its character completely on the sound as much as tube gear allows, the player is freer to experiment with speaker/cab designs that have greater efficiency, without worrying too much that some mysterious mojo smoke might escape.
If you can create the transfer function of the sound you want, you can get it from a wider range of speaker choices and designs, but get it you will with solid state.
Players usually do not know that they are in control of the tone and are responsible in solid state. A high power amp, much more powerful than the speaker can handle is not a bad thing....unless a player treats the combo like a tube amp/speaker.
If they focus on tone, at a moderate lower SPL, the power section will simply provide the drive and not impart any particular sound character to the signal. In that way, the same tone can be had at various power levels. So why try to overpower the speakers when you already have the tone dialed in at 1/10 th the power? Maybe because they grew up with tube gear that did not sound the same at different power levels, and the sweet spot for a lot of desired tone was between 99 and 110% of amp capacity. They HAVE to run high power to get tone. A solid state user only overpowers their cab or gets close to clipping the power section due to misunderstanding their system.
The usual comment is thst "I need to get over the drummer". That is not an acoustic power problem, that is a personality problem. The audience is not going to be left in the dark as to whether you are playing or not dropping to YOUR rig's sweet spot which is any level well under clipping of the amp and within comfortable excursion limits of the speaker. In the very few situations where the guitar just did not stand out because of volume level, it becomes a problem for the house PA system to fill the need. Because you have 400 watts of SS power does not mean any person in the audience will enjoy it any better running at clipping. In fact, just the opposite is the case, all improves with lower stage volume...vocals, guitars playing, dynamic range of the whole group etc. If the band can't "balance" themselves, but instead run flat out in all instruments, it is boring and not musical.
If the drummer can't play as a member of a team, fire them, they have no business in a team. Play in your sweet spot, not the drummer's ego trip. A club with 200 audience does not need much power to fully fill their consciousness. Anything bigger has a PA system that is designed to do that. But to sound good, you much take responsibility for the overall sound, not just on stage but also in the hall so be prepared to fire the sound guy if they are playing ego trips with power, his job is to compliment your sound by re-enforcing it, not creating it. If you are not having at least 20 db headroom in the house system your music is dead and lifeless in dynamics, but most systems by dead ear sound guys are pushed to have 3 or less total DR between average and peaks levels. Take control, it is your career.
All this comes back to speakers. With solid state the choice and design or even power are not the major tone consideration it is with tube gear, if sensible levels are used that compliment your music.
This is from the perspective of a recording engineer, EE, gear designer and audience member, not a player.
Holy cow! I read that whole thing. Very interesting indeed, and great first post!
Sorry about the length, sometimes I get carried away with a theme, in a stream of consciousness text, typos and all.
In all music, I am more concerned with the audience than the players or sound guy since it is apparent in live gigs the only ones not considered is the audience. The band, roadies, monitor mixer and house mixer, all have their own tastes go by but no one actually consults with or goes out into the audience to see how it sounds or if the audience is even enjoying it.
In recording I always assumed that role of being the audience's representative in the session. It seems to have worked based on the records on the walls.
Quote from: sound-pro on February 17, 2011, 02:39:02 PM
Very interesting. Can you share who you've done recording with/for?
Great 1st post indeed Sound-Pro
however , there are many way's to get more volume out of your amp , the easiest way is to add a more efficient speaker , or multiple speakers that works fairly well.
Joecool what 100 watt amp do you have that has only 1 speaker , to compare to a 10 watt .
my 100 watt amps blow away ANY 10 watt amp with as many speakers as you want to attach to the 10 watt amp with my 100 watt am on 1 lol lol lol
Rock On
Quote from: Jack1962 on April 11, 2011, 11:56:59 AM
Rock On
It was a theoretical situation pointing out how important speakers are. That said, most 100w amps will have 2x12" speakers with a fairly high spl rating while most 10w amps will have a low spl 8" speaker, this makes the volume discrepancy quite large.
Yes, that's where 90% of the discrepancy lies, 99.9% of small, cheap amps have *very* cheap (and poor) speakers.
The 10 to 100W comparison is acceptable if both are driving the same cabinet (say, a 4x12" Marshall) and there is no other loud sound source (such as a drummer) to confuse your ear.
one factor everyone forgets about is frequency! I often use a Fender 25 R for my steel... you can definitely hear it in the mix.
My bassist however cannot use her 60 Watt Acoustic practice amp with it (the Acoustic Brand not FOR acoustic)
25 wats is then > 60. seemingly.
She does use that amp when we're doing unplugged stuff...doesn't own an acoustic bass. And to agree with what's said before...get a different drummer. Two dreadnoughts electric bass and a drummer works for our acoustic blues gigs. And actually when I switch to the 000 for a few songs it pierces through to the top as it is less bassy...have to back away from the mikes.
Because we simply don't hear bass as well.
On the same token, scooping the midrange out makes an amp apparently softer then the same levels clean because we hear midrange best...That's why my steel and mandolin can get through the mix with much less power.
Actually for a too loud drummer buy him electronic drums...turn his earbuds up and turn him down in the mix :lmao:
Yeah, I hadn't mentioned anything about frequency since I was only referring to guitar. But it is true. Bassists normally need roughly 3x the wattage to get loud enough to be heard well and not be "fuzzy".
Part of that is due to not being able to hear the bass as well (human ear limitations) but alot of it is also mechanical limitations of he speaker - it is simply more difficult to produce low frequency notes, thus requiring more watts.
yes bry frequency makes a world of difference the higher frequencies will ride on top of the low frequencies.
yes in theory joecool and jm this is true , but in practice it isn't , it is true that between a 100 watt and a 50 watt amp you won't hear much difference in volume. I have a Marshall JMP and a MG10 and 2 1960 cabs if ya want to come and prove your theory :lmao:
Rock On
Quote from: Jack1962 on April 12, 2011, 06:58:46 AM
Rock On
Ears naturally compress high volumes :D
So 100 watts is actually 2x louder then a 50w much further away . ( like 20m )
As a guitarist, I've come to realize, not that much power is really needed. My band is a basic old-school punk band. (we started playing in 1978) Drums, bass, guitar, singer (if you can actually call what he does "singing"). In the past, I would use an 80 watt, 80 lb Traynor Mark 3 combo. This thing could blast a Fender Twin off the stage, no problem. It was way too much power! I only had occasion to turn it above 3 once. That was at an outdoor gig at Nathan Phillips Square.
I realized how much I hated hauling this 80 lb monster around. Now I use an old 20 watt Supro, a small combo with a single 10" speaker. It's so small, I can carry it to gigs in my backpack. I installed the best 10" speaker I could afford, an Eminence Ragin' Cajun. It's rated at 100dB SPL sensitivity. I've found this setup to be more than enough, even with an aggressive drummer. No problem being heard. Strangely enough, I'm still not turning this amp up much past 3. ???
I would think that a 20 to 30 watt amp in a combo with something like the 12" Eminence Wizard (103 dB SPL) would be more than enough for any situation. In fact, I'll bet that a speaker like that could make a decently designed 10-watt amp be heard just fine.
Quote from: Puguglybonehead on September 18, 2011, 01:07:24 PM
The reason why people think tube is louder then solid-state , is because . well SS practice amps are always given *s!!t* speakers .
10W can do some serious *s!!t* with a 103db monster . ( no less 30W )
but i think it can at most do ... 105db .
i don't know about 30W , though . But my insane 30W DSP amp ( i have never been able to crank it up above 2 ) , came with a unnamed mad 10" 98db , can do some serious sound . It even won those dumb AC30's
I fixed some math and stuff in the first post. You can't just add speakers to get more volume. If you take two 96db/watt speakers and run them together each with their own 1watt source, you would come out with 99db. If you ran them together splitting a 1 watt source, you would still only get 96db. This is assuming a large distance between the speakers (say one on each side of the stage or farther apart). If they speakers are in a single cab, they will work together acoustically, producing more volume per watt and also producing more vibrant lower tones due to the increase in cone area.
So the big advantage of more speakers is two fold: tone (yes, it will sound different) and maximum wattage handling.
I apologize for any confusion.
The key thing to remember is use efficient drivers. It doesn't matter if you have a single 8" or two full 4 x 12" cabs, the more efficient the drivers, the more volume you get. Look for at least 97db, ideally 100db or better.
Sound Pro,
go ahead - 'spress yerself! Couldn't agree more. It's the sound, not the volume, that leaves an impression. I mean, even Cream, loud as they were, was very considerate of the sound, all well balanced and clear for each player. Conversely, after weeks of practice, and only one warm up gig, when my nephew and I finally got a good tone dialed in at this club for our Costa Rica debut, after 2 or 3 songs I noticed the sound was all messed up. I told the promoter to track down the culprit. Seems the club owner, accustomed to louder, more aggressive hard rawk than our own down home, mostly accoustic southern blues thing, kept sneakin over and cranking up the board - after we had it set just right for the room. Oh, well, he did recently ask me when I'm coming back...cabs
Fascinating. Quite informative, as well. Who do y'all recommend for a manufacturer of efficient, reasonably priced speakers? Back when I was gigging regularly as a bassist, the Peavey Black Widow was one of the most efficient speakers out there-but I wasn't that crazy about the tone. Nowadays, I'm playing guitar primarily, and am thinking about downsizing my rig, so speaker efficiency is a definite concern.
For speaker efficiency, have a look at some decent quality ceramic speakers. The "vintage-tone"snobs seem to love alnico, but those speakers are seldom as efficient. If you can find the full specs (including the all-important SPL rating and frequency range) then you can get some idea.
Eminence make really efficient speakers, full specs available. So do Weber. (but they don't publish their full specs) Also, decide on which speaker size works best for you, tone-wise. The larger the speaker, the better chance of it being more efficient. Lots of loud 15-inch, 12-inch and even 10-inch speakers out there. 8-inch or smaller and you're starting to lose out.
Read lots of the reviews online. They may seem subjective, but they've usually steered me right. Anyways, Eminence and Weber both make great sounding, loud speakers.
Don`t forget another important thing - specific "voices" of different speakers.
One speaker maybe good for vintage sound but poor for modern.
http://www.youtube.com/watch?v=jWK0sa7tlfI
Most of "vintage" speakers do have a huge boost (sometimes 3 to 6db more than the overall ratting) in high mids (in the region of 3KHz to 6KHz). I do think you should really be carefull when selecting a speaker based on efficiency. Try to find response curves and see if most of this efficiency is located in frequencies you don't want to push too far. Overwize you will need to filter them out somehow and obtain an overall efficiency of the speaker + filters that is not what the overall spl indicates.
E.g. if your tone is more in the 200 to 2000 Hz frequency range, a speaker with overall 100 db/W.m with a speep boost at 4KHz won't be more efficient for you that a 98db/W.m one which have a boost precisely in the frequency range you seek.
Many if not most of modern guitar speakers are in the high 90's to low 100's in dB's. Even high excursion bass speakers are usually in the high 90's but the compromise is usually less highs.
This is for 12's and 15's. As you go smaller, especially with 8" and 6 1/2" speakers, the sensitivity is often lower, in the 92dB range.
Most manufacturers will not only give all the specs, but will include a frequency graph. Every speaker will have a rather shallow low end rolloff, relatively flat across the mids, and then have a large peak between 2 and 4kHz followed by a treble rolloff that may extend gracefully to 5-6kHz or beyond, or be rather ragged.
A guitar pickup is similar, with it's "resonant peak" producing a characteristic tone.
Bass and PA speakers will usually use a crossover selected to be below that large peak, bass less so.
Tube VS SS watts...an endless argument. Let me give my take. When you reach the limits of a SS amp, there won't be much beyond it's limits. A 100watt amp may be rated 100 watts @ .05% distortion. Once the rails are hit, there may be nothing much left above a certain point.
With a tube amp rated at 100watts @.05% distortion, may be capable of 200 watts @ 30% distortion and sound great doing it.
The tube amp may keep putting out far more than it's rated power, at a very high distortion level, but still sound good. With the SS, the possible output will be limited by it's power supply limits, and at high distortion, may not sound very good.
My 12 watt Princeton Reverb will put out a lot more than a 15 watt SS amp using a TDA2030 power amp chip...a LOT more.
Quote from: Steve DalllmanA guitar pickup is similar, with it's "resonant peak" producing a characteristic tone.
Just to remark that I've done a bit of modeling of guitar pickups where it seemed that the input impedance of many amps was too low and seriously damped this self-resonance, and lately building some high impedance buffers which has confirmed that impedances in excess of 1Meg (e.g. ~5Megs) lets the pickups "sing" more, are more tonally rich (and that's into a s.s. amp). Adding shunt capacitance to bring this resonance down in frequency, VariTone style, is something I'm also fooling with.
Quote from: Steve DalllmanTube VS SS watts
Not taking sides, since I use one of each, but
Rod Elliott at ESP has some interesting views on the very different output impedances of each.
Another factor is that when a s.s. amp clips it presents the speaker with an effective short circuit, and thus high damping, but when a valve amp with an output transformer clips di/dt goes to zero and it's more like an open circuit; the upshot of which is that during clipping the speaker in one is highly damped while in the other it's effectively cut loose.
Great explantions on this subject :dbtu:
I love hearing JM and Joe lay the info down for ya , so here's a twist to this , why is a lower wattage tube amp louder than higher wattage solid state amp , thru the same speaker.
Again Rod Elliott at ESP has an interesting take on this;
http://sound.westhost.com/valves/valve-trans.html (http://sound.westhost.com/valves/valve-trans.html)
http://sound.westhost.com/valves/valve-trans2.html (http://sound.westhost.com/valves/valve-trans2.html)
There are a number of factors in play, but the essence of this observation is that a valve amp has a much higher output impedance than a transistor amp, perhaps as much as 20 ohms compared to a fraction of an ohm. This results in a valve amp behaving somewhat like a current source, while a transistor amp behaves much more as a pure voltage source.
Into a resistive dummy load there is little apparent difference between the types, but the situation changes considerably when they drive a real world loudspeaker load. The impedance of a real loudspeaker cab is anything but constant across the audio spectrum and the drive voltage available from a valve amp tends to track these changes of impedance and thus seems to have more headroom to overload than a transistor amp of the same power.
Apart from technical considerations, I have been running a 60 watt valve amp and a twin-50 watt solid state amp, both homebrew, for guitar and keys/synth into the same cabs for many years now, and as a player the difference is very apparent when I have been forced for some reason to cross over and use the valve amp for keys or the solid-state amp for guitar. Running keys into the valve rig results in a more or less dirty/muddy output at all levels, while running guitar into the transistor rig has a "distortion wall" at overdrive that sounds downright nasty.
The inherent and progressive distortion of valves sound better with tenor guitar, specifically, but keys, PA, and I note bass guitar, sound better with the ample clean power of a solid-state amplifiers run below clipping. Bass rigs frequently contain some form of signal compression as well as very large amplifiers so they rarely clip.
The output impedance from the tube is between 3k ohms and 8k ohms depending on what tube you are using. however I agree with most of what you are saying , the real difference is drum roll please , the tube is indeed a constant current source due to the output transformer , the transistor amp has it's signal dump directly onto the speaker. Myself I have and use both types tube and solid state I prefer the solid state for keys because the amp I'm using is a Peavey Musician you can use it for anything , best frequency response I have ever seen from a stock production amp. for guitar and bass I usually use tube amps because of the output power , I generally don't use anything larger than a 50 watt guitar amp for Bass I use my vintage Ampeg SVT with a 8x10 cab and a 15 jensen that I really don't remember where it came from I"ll put it up against any 500-1000 watt bass rig anytime lol
Such a good thread. While I am fairly novice to guitar amps and their application, I used to compete in car audio and many of the same principles apply here and have been stated.
Every 3dB is doubling the volume. So to double the volume get a 3dB more efficient speaker, double the cone area, or double the power. In car audio completion you could also port the enclosure to give 3-9dB boost at the frequency the port is tuned for.
Quote from: MTmopars on April 05, 2014, 10:08:39 AM
No. It was established that it takes 10db to double the volume in the first post :).
The 3db boost in volume from the methods you mentioned does not double the perceived volume.
In car audio competitions you measure SPL. Does a given system with a 200W amp sound twice as loud as the same system with a 100W amp?
Double the power does not equal double the volume, you need 10db increase to sound twice as loud.
I stand corrected on part of my post. 10 db is doubling perceived volume. 3db is the gain from doubling power or speakers. It has been about 10 yrs since I was active.
I'm straying a bit here but.... I think perceived volume has a lot to do with the amplifiers natural EQ curve, cause if an amplifier has a good mid range response, and is of good quality it is going to be LOUD. I've owned many different amplifers, tube and solid state, and the higher quality solid state amps like the Randall RG's and Ampeg SS and VH series heads through a good cab are just as loud as equally rated tube amps, and they cut no problem too (when dialed in right). No one can say an Ampeg SS-150 or Randall rg100es can not cut through a mix, they cut through like butter.
I am very very new to this whole topic and got myself a Woodstock GX-55R Amplifier the other day cheap from a second hand shop. Yep the question of watts came up. I don't know how many watts it has.
But I have been told itno good for a bass guitar.
Yeah I don't even have half the knowledge of people here however I have found reading everyone's post absolutely fascinating.
Cheers all.
Quote from: Lady_Azurewolf on April 11, 2023, 05:50:40 PMI am very very new to this whole topic and got myself a Woodstock GX-55R Amplifier the other day cheap from a second hand shop. Yep the question of watts came up. I don't know how many watts it has.
Cheers all.
Go ahead and start a new thread and share a few pictures - specifically any labels or markings on the amp. We should be able to help!
I use two Crate Power Blocks to pump four 4x12 early 1980's Laney cabinets , loaded with Celession Greenbacks and Fane speakers with two Peavey 2x12 cabs loaded with Sheffield 1230 speakers .
Before I started using them, other guitarists were telling me that the 150 watts from the Crate CPBs , were not going to be as loud as my Marshall's, Carvins or VHTs .... Boy, were they wrong !!!!
The problem with this perspective is ultimately useable volume and wattage when you do a more thorough test of 100 Hz, 1 Khz, and 10 Khz with a sine wave. 1-watt @1 meter is using a 1 Khz sine wave, so it's dB rating isn't always the most reliable in terms of overall performance and projection.
Relative to this is the hardware distorting within a certain pitch range, as well as the speaker. You have to be prepared for potential crossover distortion, and many amps greatly lose efficiency in the lower frequencies at any volume. I agree that the speaker is one of the most important components regarding performance all across the board, and changing speakers may give you better performance and with a few more dB of useable volume, and that's a lot.
You must also take into realization that RMS/Peak wattage isn't telling you a whole lot in again, relationship to 100 Hz, 1 Khz and 10 Khz. Once you incorporate a speaker as the load on the circuit, you aren't dealing with watts, but the VAR of a resonant circuit. This is the precise point at which current and voltage meet in phase, and you get the most power transfer.
I've seen the most efficient systems built by using 100 Hz instead of 1 Khz exclusively to rate a speaker as well as the amp, and the VAR in equivalent effective wattage might be 10 watts compared to a 1 Khz sine wave resonating at 100 VAR(watts), or it might still be 100 VAR(watts) when using a 100 Hz sine wave, and that's phenomenal.
This is the final attribute where you also start to realize efficiency is overrated. I would rather have 100 effective watts of Class-A @ 100 Hz than Class-A/B or worse yet, Class-D. A really well-designed Class-A amp focused on VAR for 100 Hz resonance just as much as 1 Khz will be an animal not much can compete with. It's why some of these really old tube amps that weigh 150lbs will be just 30 or 40 watts, but they can compete with a modern Class-A/B or D that's full blast and rated 200.
Quote from: JonnyDeth on March 20, 2024, 08:56:50 AMThe problem with this perspective is ultimately useable volume and wattage when you do a more thorough test of 100 Hz, 1 Khz, and 10 Khz with a sine wave. 1-watt @1 meter is using a 1 Khz sine wave, so it's dB rating isn't always the most reliable in terms of overall performance and projection.
Thanks for bringing up these points - all of them very valid and interesting! While I am an advocate for solid state gear, I am by no means an expert and I love reading the in depth stuff some of our users here bring. Thanks for joining the forum!
Amplifiers are rated RMS into a resistive load, so VAR is not a factor at the amp side of things.
Well, looks like I wasted all that time going to college for electrical engineering, thanks for the clarification ::)
Speakers aren't resistive loads, and there are many types of amplifiers. In regard to audio frequency amplifiers, VAR is absolutely critical.
What is VAR and what does it have to do with anything ?
Quote from: JonnyDeth on March 20, 2024, 02:56:58 PMWell, looks like I wasted all that time going to college for electrical engineering, thanks for the clarification ::)
If you can't apply it, I guess you did.
Amplifiers are rated into resistive loads to take reactive power out of the equation.
Note that I specified amplifiers in my earlier comment to exclude what you said about speakers.
When one walks into a new room, it's best not to have the flamethrower on and start out with the idea that everyone else has it wrong.
Quote from: g1 on March 20, 2024, 08:39:30 PMQuote from: JonnyDeth on March 20, 2024, 02:56:58 PMWell, looks like I wasted all that time going to college for electrical engineering, thanks for the clarification ::)
Get a grip, you're the one being rude. The thread is about wattage, dB and output of a combined devices and how they relate to one another.
What I said is absolutely critical, and I was simply offering some factual information that is helpful based on the entire purpose of the thread from the OP. I wasn't rude, and I wasn't condescending, I just made a point, and you had an immature reaction twice over now. You literally tried to crybully me and I'm not interested. I'm under the impression I already need to be prepared to block you after that immature harassment.
VAR is what truly matters unless you're operating at a single frequency. Not all companies test their amplifiers the same way, but those that do it correctly will test it into an RLC tank circuit, or at least, an LC circuit. If they have built something truly special, they will test it with an LC circuit for 100 Hz, 1000 Hz and 10,000 Hz and they will also test it with sweep going from 100 Hz to 10,000 Hz.
So, any given amplifiers selected at random won't necessarily perform as well at 100 Hz as they do at 1 Khz.
Typically, the further you stray from a 1000 Hz sine wave in frequency, the worse the amplifier will perform in it's production of VAR, and for general purposes, we can use the 3 fixed frequency points defined by factors/divisors of 10 in the >< connotation of 1000 Hz, and regard VAR as watts.
An amp screaming loud with 100 watts @1 Khz may only push 20 watts at 100 Hz, and thus the owner is grossly dissatisfied with it's performance. Now a lot of amp manufacturers will produce a design that is so effective, but there are some out there that will produce nearly the same wattage at 100 Hz as they do at 1 Khz and 10 Khz. These are often used in the subwoofer competition industry and when a brand really wants to make an impact, they will produce test data for those 3 frequency points, design a speaker specifically for a selected frequency point, and that amp and speaker in combination will be at resonance producing the spec'd wattage because the manufacturer took a lot of pride in it's design.
You can always do the math using your desired speaker and run the tests yourself after calculating the necessary capacitor value to see what you get at 100, 1000 and 10,000 Hz.
Quote from: g1 on April 05, 2014, 01:37:52 PMIn car audio competitions you measure SPL. Does a given system with a 200W amp sound twice as loud as the same system with a 100W amp?
I got tickled when I read this :) as much as I groan when I hear them thumpers driving by I am intrigued by the idea of a contest which I presume the goal is to be the loudest?
If so I think I will keep an eye out for any local event like that it would be fun to watch
8)
Quote from: saturated on March 26, 2024, 02:34:14 PMQuote from: g1 on April 05, 2014, 01:37:52 PMIn car audio competitions you measure SPL. Does a given system with a 200W amp sound twice as loud as the same system with a 100W amp?
8)
That question is why you really want to understand what VAR is, how to calculate the capacitor for your selected speaker, and then run tests using a sine wave @100 Hz to see how many VAR/Watts it actually sees from that amplifier, probably 10 Khz or at least around 6 to 7 too.
The kid that set the original world record that's since been broken used a specific series of pioneer subwoofer and that series of subwoofer amplifier. Pioneer spared no expense and recruited a degree bearing engineer and techs to design the entire line. They designed the amps so what they produced @1 Khz was also the same as they produced @100 Hz as well as all the way down to 25 Hz, this is why VAR is actually a critical detail when it comes to how much volume you can expect from the lows, mids and highs of a particular woofer and amplifier set, and what is the quality also going to be like.
A speaker whose resonance Q ranges down to 100Hz and still sees 75% of the VAR/watts it will see at 1 Khz will be an absolute monster, even if it's only rated for 90dB rather than 100. The dB sensitivity is still generated by 1-watt @1 meter, so it's not the critically defining feature to how much volume it's ultimately going to produce. It's just a test produce for reference when you're speaker shopping. If it's 110dB vs 95dB, but the 95dB speaker handles 5x the wattage, it's generally going to be louder than the one rated at 110dB when you max their wattage, but it won't be obscene when you compare them, and it's also likely to be better quality in sound fidelity.
I don't have extremely deep interest in car audio, but I do like having a competition class subwoofer in the trunk of my vehicle. My focus for audio engineering will always be focused on music equipment, but also when it comes to signal processing technology, that's going to include car too. I have some rather clever ideas for subwoofer crossovers that will give you brutal volume and thump out of a cheap ass subwoofer and amplifier that I've used in the past. When I finally moved to a competition subwoofer and much stronger power amplifier, it was significantly louder, but only about 20% with a significant amount of rumble. The cheapo was still only about $80 total investment excluding the enclosure I built, and the competition one setup was about $350! It was definitely worth it, but it also wasn't an obscenely dominating increase in performance. I've also been through 3 competitions subwoofers since that one after accidently frying it and having to buy 2 more is what was obscene.
I'll tell you a funny anecdote for your delection.
About 30+ years ago I had made an active loudspeaker system consisting of two satellites (mid-treble) and a subwoofer. This was made according to a Siegfried Linkwitz design.
I had bought 60W modules to power all 5 speakers, but at the time I was not very proficient. Some decades later I threw the electronics away and replaced them with DIY class-D modules (kits). That worked great.
Just I did not know what power they were outputting. In fact I was not interested in the power, but rather in the voltage headroom, in order to avoid them clipping.
So I devised a small µC operated analyzer that drove 10 LEDs, to show average and peak hold values, to give me a clue where I was. One for each amp, so 5 of those in total.
The unit was tested thoroughly on the bench. After installing, the LEDs did not register.
They did not show anything. Until I found out, that even after playing in the living room at party loudness levels (which you would not like to be subjected to for long), the power output was still below the threshold of the display: 1Watt. You would not believe how loud 1W is.
I then changed the code and installed a 10:1 "loupe" that automatically reverts to normal once the threshold has been triggered, before it falls back with a delay of a minute.
The measurement was by no means scientific, just a conversion using an 8 Ohm resistance, but it gave you a very good indicator.
The interesting thing was that the dance of the LEDs remained the same (the display being logarithmic), regardless of the power. It also showed that, beyond that 1W point, the wattage was climbing shockingly fast despite a perceived mediocre increase of loudness.
We all know that but it comes as a surprise when you encounter it.
Quote from: aquataur on April 21, 2026, 11:15:32 AMI'll tell you a funny anecdote for your delection.
You never caluclated the power for any of this to make sense because it doesn't. I'm an electronics engineer, not a DIY guy which all due respect, is a community with a lot of nonsense and pseudoscience in how things work, what information means, the literally quantum theories of materials, circuits etc. etc. etc.
Without simply clamping the amplifier, getting a voltage and current reading with a 1 Khz sine wave test tone, there's not much to be said other than you made a cool DIY project that worked well enough but you have no effective understanding of.
I've been there. I built many things like this when I was a DIY nomad for about 6 years but eventually, I got sick of now truly understanding and all the nonsense from forums and social media fraudsters and I went to a technical college that teaches the patent science when I was 32.
Every single device and project is just and endless universe in itself. There's endless options, endless details to modify through D.C. and A.C. analysis, probing every circuit node for a variety of test equipments producing data and then modifying things based on that.
1 watt is very loud through a very light weight cone with a modest magnet size and a very hot signal pouring into it within it's bandwidth where the cone's damping factor doesn't result in physical distortion.
1 watt under the right circumstances will give you permanent hearing loss.
Wattage in itself is a misgiving dataset because inductors and therefore speakers do not see wattage, they see VAR; Volt Ampere Reactance. This is calculated based on the phase angles of voltage and power meeting in timing at a very certain point, and that chronological synchronicity point tells you the peak resonant frequency, the VAR which we can relate virtually to wattage, and the effective bandwidth to power efficiency based on the circuits Q.
It's just a very complicated process in terms of what you cannot learn through DIY study in 99.99999% of cases. You have to go through very structured curriculums of some form and commit to them. Fulfill them in 100% of requirements and if possible, take quizzes and then tests on them.
In the end, there's no supplementing a curriculum with DIY wandering and misunderstandings based on personal ideas and association of those ideas with science based information you simply don't understand.
Udemy and the other online non-credit colleges have a lot of great courses that will take you the distance to being an electronics engineering, but take that with a grain of salt because they all teach "conventional current theory" which is a theory in particle physics that's unfortunately a pseudoscience.
You'll be a competent engineer but never truly a scientist. Technical colleges teach the electron model for mass, energy and motion of all phenomenon in the universe, not just technology and electro-chemical events in nature or even manmade industrial processes.
Learning conventional theory really puts a despicable set of shackles on the student's brain. It can certainly be overcome after the fact, but you have to
really want it. It doesn't just correct a shitload of electrical theory they teach wrong but all physics from quantum to classic scale and the countless things they have wrong.
Every field of science today is based on the proton model of mass, energy and motion for understanding all phenomenon in the universe and it's an ass backwards pseudoscience equivalent to shoving food in your crack and expecting it to come of your mouth as feces.
I suppose when all of these theoretical physicists in media make all sorts of ridiculous claims based on totally fraudulent theories, that is virtually the crap pouring right out of their mouths.
This is why technology has been at a near dead stand still for decades.
I totally agree with you, although I don´t know what your overall message is and whom you direct this towards.
As far as my little box goes, I made quite clear that this is non scientific, however it gives me a good gauge for how close to clipping I am. Labelling such a scale in Volts is kind of awkward and non portable, but an approximate conversion to
amplifier power is familiar.
My midrange drivers are low efficiency, and they need considerably more power.
None of this takes the efficiency and thus the
loudness into account, and it is not meant to.
I was also interested in seeing if and how much peak power and average power differs for the different frequency ranges. That comes into the bargain.
The idea for this box goes back to a design by J. Linsley-Hood, who too wanted an indicator for the available headroom too, although the practical realization was entirely different:
QuoteI use the term "watts" in this context very loosely, in that what one is really referring to is a p-p voltage swing, which could only be related to watts if one knew the RMS equivalent value - very difficult to determine for music waveforms - and if one's loudspeakers were truly resistive loads of a known value. Nevertheless, the hi-fi industry has grown up around the use of this terminology, and I must do the same.
Build a Peak drive indicator, by J. Linsley-Hood, Hi-Fi News & Record Review, p.63ff, Oct. 1980.
So you may call that amateurish, but it serves the purpose.
Anyway, the purpose of my original post was to illustrate the wrong perception of loudness and amplifier power by telling the amusing story, and not to claim re-invention of the wheel.
Quote from: aquataur on April 22, 2026, 12:19:19 PMI totally agree with you, although I don´t know what your overall message is and whom you direct this towards.
As far as my little box goes, I made quite clear that this is non scientific, however it gives me a good gauge for how close to clipping I am. Labelling such a scale in Volts is kind of awkward and non portable, but an approximate conversion to amplifier power is familiar.
None of this takes the efficiency and thus the loudness into account, and it is not meant to.
- Build a Peak drive indicator, by J. Linsley-Hood, Hi-Fi News & Record Review, p.63ff, Oct. 1980.
It was that you were saying things in such a way that you did word them in regards to being scientific even with prefacing it with it not. When you start using the unique dialect to certain formal fields, it's still taking responsibility for those terms under the effective understanding in that field.
When you say the voltage would tell you when you were close to clipping, it was a "metric" you had created based on the gear you smithed together to show you some form of measurement.
In truth, that is the basis for all sophisticated, recorded science. Build something that generates information that is consistent in relationship to what you're also witnessing and then refine it.
In engineering, we tend to create a theory, build something from our imagination based on that theory, and if we successfully generate the effect we were envisioning, we refine it by applying staples of science because of where the world is at in technology.
With an 8 ohm impedance for your device though, you're seeing a lot of current. Without seeing the device, I doubt it was actually 8 ohms and much higher. There's also the fact that because of how you're obtaining your signal into those devices, if that device clips the active semiconductors or their passive diodes inside, it's also going to be witnessed by your speaker.
Whatever one experiences, so does the other.
I would bet your gizmos are far higher in resistances to see a large voltage drop but not current. If you're generating theoretically 100 watts, that's surely 3 to 4 amps of current.
Your VAC output is likely to be approximately 20 to 50 volts depending. Current for a 100 watt amp will typically be somewhere between 1.5 to maybe 3-4 amps and of course, with the voltage within the range I gave so it's calculated to approximately 100 watts.
In terms of isolating your monitor setup, it's much better to sample the signal with an incredibly high resistance and then increase the amplification within your device, design a driver that samples off that amplified signal to control the visual monitor, and so if you were to max blast your amplifier and speakers, if something distorted within your gizmo, that huge input impedance would make it totally inaudible within the speaker.
Just finding it within the speaker's signal with diagnostic equipment would become a pretty difficult task and possibly impossible.
I had fun as a hobbyist, but going to school freed my mind allover again and gave me a far more complex medium to create in than music and I'm a symphonic shredder that can hold my own against the biggest names on Earth. I have a style that no body sounds like, not even slightly, and invented a technique that's never existed I call Dypeggios.
There are much better guitarists, but I can still outplay them if that makes sense.
Anyway, I'm neck deep in my own company development and hopefully will launch my guitar and general audio equipment as planned by December this year. I have 3 preamp stages nearly complete that are out of this world. Instead of claiming tube emulation, I outright just configured the transistors to physically do the same thing as tubes and what do you know, unlike every tube emulator, simulator etc. out there that has ever existed, these simple circuits sound indiscernible from tubes.
They fizzle, they zing, they glitter when you hit pinch harmonics instead of grind. It's outright comical to how simple that is, but I'm digress and boasting. My passion for creating in electronics opened up the universe to my control.
Quote from: JonnyDeth on April 22, 2026, 12:45:21 PMAnyway, I'm neck deep in my own company development and hopefully will launch my guitar and general audio equipment as planned by December this year. I have 3 preamp stages nearly complete that are out of this world. Instead of claiming tube emulation, I outright just configured the transistors to physically do the same thing as tubes and what do you know, unlike every tube emulator, simulator etc. out there that has ever existed, these simple circuits sound indiscernible from tubes.
Be sure to share here when they come to market - we love hearing about new solid state gear!
This might help explain The VA relation in AC circuits
https://www.youtube.com/watch?v=15dskimsfyM.
A-V phase in the electrical grid can cause problems,, otherwise they waste power.
The VA issue is exactly why amp power is measured into non-inductive (resistive) loads.
Measuring power into resistive loads takes reactance out of the equation so we can compare apples to apples as far as raw power capability.
Aside from that, with inductive loads, output impedance (damping) becomes a factor. As does frequency response and transient response. These factors are why amps sound different in terms of loudness even though they may have the same power specification into non-inductive load.
Quote from: g1 on May 04, 2026, 11:41:55 AMThe VA issue is exactly why amp power is measured into non-inductive (resistive) loads.
Never thought about that, but it makes sense of course.
There are car audio and PA type speakers that, on paper, have similar characteristics to guitar speakers in terms of frequency response, resonance, impedance curves and whatnot. Specifically, so-called "midbass" or "midwoofer" speakers, Some boast really huge power handling, like even a 1000W for one speaker. I don't recall seeing efficiency quotes of more than 98 dB on these things.
Here is one claiming 3000W RMS: https://ds18.com/products/pro-3kp12-8
(https://ds18.com/products/pro-3kp12-8)
The resonant frequency and cited range seem good for bass. Sensitivity is only 95 dB though.
This 1250W one claims a respectable 99dB, a more extended frequency response from 45 Hz to 5 kHz, and a 68 Hz resonance: https://ds18.com/products/12pro2500mb-8 (https://ds18.com/products/12pro2500mb-8)
A 4x12 cab loaded with these would be completely insane. :loco
I'd love to experience what these types of speakers are like for guitar, for sure.
Quote from: Kaz Kylheku on May 21, 2026, 12:23:02 AM...car audio and PA type speakers...
I´d think - nothing. They would not survive the turn-on moment.
My brother once installed such a thing in this car. It boasted some insane cone excursion capability.
I warned him, that they need a volume to work against, as a spring-mass system. Needless to say, he turned the booster on, one giant excursion to the front and back, and gone it was...
You can only do so much to speakers, one is how much air it moves, but then you must compromise on other aspects.
Guitar speakers are usually stiffly suspended, made for open cabinets. Those speakers will be totally unsuitable.
There is nothing new under the sun.
Quote from: aquataur on May 21, 2026, 03:35:43 PMQuote from: Kaz Kylheku on May 21, 2026, 12:23:02 AM...car audio and PA type speakers...
Not exactly.
It's a gamble as any speaker change is with any audio system of any kind. I have a 4x10 cabinet with a couple car subwoofers and some Radioshack woofers that have enough high frequency response and dB output that they sound great for guitar, also car speakers.
I must have 20 different amps, 50 to 60 speakers, a dozen stand alone cabinets.
Cone materials have damping factors which is what plays the primary role in dB and rated sensitivity at 1 watt from 1 meter with a 1 Khz sine wave.
Pro audio speakers are rigid but still move and can move a lot of air, guitar woofers included. I have some guitar woofers with zero movement and you can't put the bass beyond 4 or 5, but they still thump and are in a sealed cabinet. I have quite a few sealed cabinets, open back cabinets and cabinets that open and close.
I have woofers with *s!!t* for upper midrange let alone treble, I have woofers that are so tinselly and grindy they're useless for guitar even though they're guitar wooders.
I have polymer cone PA woofers that are some of the best sounding guitar speakers I own. They smooth over the high end and get rid of the excessive solid-state high, even order harmonics that gave solid-state the "harsh" reputation.
When I improvise a speaker from whatever intended purpose, I look at the specs to see if it's at least possible to use it for what I went, then just as obviously, start plugging it into different devices to see what comes out of it. To datge, I think polymer cones even for guitar sound superior to paper, but no one mainstream is producing polymer cone PA/musical instrument speakers that I'm aware of.
I also just got some aluminum cone 10's, also guitar speakers with of course, the fabric accordion suspension. They'll pose to be interesting.
The guitar 12's I had that were the first plastic guitar woofers I used were sold by Dayton Audio out of Ohio as "aluminum", and instead were polymer with aluminum powder in the plastic; I was not happy at all.
As it turned out, they were a blessing in disguise and because they have fabric accordion suspension, I painted them flat black and they're in my custom built 4' x 4' x 18" 4x12 death stack.
Nothing is so definitive, it's why I'm an electronics engineer, not just a symphonic shred guitarist. If I thought the way you do, I never would have wandered my way into college for a science degree by my early 30's
An opinion is just a snapshot in time. Dependent of what one has encountered, his opinion is formed.
Different encounters may motivate somebody to revise his/her opinion.
An opinion is always right for a given moment and given person, but being just a facette of a much bigger total, it does not claim universal validity. If somebody does so, they are on a questionable path.
