May 07, 2024, 07:27:48 AM
First real build. LM386.
Started by flester, December 20, 2017, 04:11:47 AM
flester
Quote from: Katoda on January 31, 2018, 09:26:57 AM
A jack like this one, but a mono version. Or stereo, doesn't matter. Plastic 6.3 mm jack
What is it called?
Sent from my SM-G935F using Tapatalk
Katoda
It is just a plastic jack, no need for a name. You get these mostly everywhere they sell components, from Ali to Farnell and everything in between.
They are sometimes called 'Cliff style' but that is a brand name.  Maybe 'leaf' style?
Neutrik NMJ4HF-S would be an example.
flester
Quote from: flester on January 23, 2018, 06:24:42 AM
Quote from: flester on January 16, 2018, 02:10:25 PM
Quote from: phatt on January 12, 2018, 08:14:07 AM
Hey some nice blues riff there :tu:
BTW, looks like you are driving a hifi type speaker box,, if so then be aware they are woofers and generally have a low SPL,, a real guitar speaker will give a much bigger sound,, louder per watt of input.
A friend has a 12" guitar speaker I can use. Time for a bit of joinery I think
Works as a harmonica amp too. I made the mic using a headphone speaker. The black box on the right contains a Kemo preamp module, needed to overdrive the amp. A Danelectro overdrive pedal works too. https://flic.kr/p/22mhiVv
Amp seems to have got more 'scratchy' since I first used it. Usually if I slightly overdrive it but its OK when I run it flat out (i.e. give it the full 0.75W !). Could some component have deteriorated  from being overdriven? or did I just not notice at the start?
flester
Quote from: g1 on January 31, 2018, 08:50:10 PM
I meant to ask about the switching part. I want it to switch off the speaker when a plug is plugged in. Is it just called a switched jack?
flester
Finally did the joinery ( takes me a while to do stuff!) I now have the amp and some pedals powered by a single PS in a case and going in to the 1x12. Plenty loud for home use and a great platform for bigger amp builds.
Speaker good for up tp 80w.
1w amp and pedals into 1x12 cab
https://imgur.com/gallery/lKMg7CR
Quote from: flester on April 08, 2018, 05:22:45 PM
Yes very common switched socket,, the plastic ones lift the connection when you insert a plug. there is a pic at top of page.
Quote from: flester on January 05, 2019, 05:26:04 PM
Yes a real guitar speaker makes a much better sound. 8|
Quote from: flester on March 23, 2018, 09:07:55 AM
If you changed the speaker then you will hear different freq than you heard through other speakers. It was likely there you just did not notice it.
