April 29, 2024, 10:57:50 AM
Boss Katana50 MK1
Started by Monkeyb61, October 17, 2022, 02:02:25 PM
Monkeyb61
Hi,
Does anyone know if the existence of a schematic for a  Boss Kantana 50 is available ?
It seems only to exist in people heads like the fabled unicorn.
Regards.
It is very unlikely you will find a schematic for this now, if ever.  It's possible you will find a wiring schematic that breaks down how things hook up inside (PCB 1 goes to pins A, B, C etc).
For what reason do you need the schematic?  Most times amps like this either break with a simple thing (need to resolder a jack, or replace a potentiometer, maybe blown speaker) or are completely unfixable (DSP module dies).
Monkeyb61
I bought the amp second hand, No output or function lights working.
I believe the main power amp TDA7293V had been damaged by a power spike and found to be fried.
I replaced the chip and it checked all components upstream from the chip. All were found to within spec, but the the amp still is dead.
Any idea's would be apricated.
Thanks
Tried a Factory Reset?
Hold down the Panel button & turn the unit on.
All of the LEDs should begin to blink.
If not, you are SOL.
Have you checked each voltage regulator?
Many Boss/Roland schematics seem like fabled unicorns if you are not authorized to have them.  :)  They are very protective of their IP.
I'm a bit surprised to see the MkII is leaked and available online.  The MkI is not though.
Here is a thread with a couple bits of the schem and some info about the less common pcb mount fuses:
https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/963156-need-help-repairing-a-boss-katana-50-mk1
