May 07, 2024, 07:30:55 AM
SWR Workingman's 12 combo - Full wave Bridge spec
Started by mikebarg, December 10, 2021, 12:10:06 PM
mikebarg
I'm working on an SWR Workingman's 12 combo(100 watts). I need  a full wave bridge rectifier. I have the schematic, but it doesn't show a spec for the rectifier. I checked the board and the spacing looks like .5 inches between legs. I'm thinking 5amp at 400+ volts should be enough. Any thoughts?
With 4 ohm load, 100W requires 5 amps.  I think you need some leeway there.  I would guess 8 to 10A would be much more reliable.
mikebarg
It's a DB604. According to the datasheet that's a 400V, 3A.
I saw that data sheet, but in general I expect a 604 bridge to be rated at 6A 400v.  In any case 6A sounds like a better choice than 3A here.  Or 8A even.
mikebarg
I agree. Thanks for the input. I'm wondering if this part had been replaced before. The board is marked with an X next to the part and the size is a little too small. The legs were bent out a little to get them through the board.
I could be wrong, but I often mark boards when I work on them just for reference.  I suspect your X is really a +.  Someone marked the + corner so they wouldn't have to figure it out later.
Quote from: mikebarg on December 10, 2021, 10:08:58 PM
Quote from: Enzo on December 10, 2021, 10:34:20 PM
Was that a download, or was it the 'specs' listed on the datasheets360 page?
That 'specs' page looks to be their own list with a typo.  The pdf they offer on that page shows the part to be 6A. (see attached)
mikebarg
That makes since. It wouldn't be the first time I got inaccurate information online.
I went ahead and pulled the part and it tested good. So, I need to go back and re-evaluate.
