May 21, 2024, 03:43:17 PM
tone frequencies
Started by benzer, September 26, 2007, 05:10:56 AM
benzer
at what frequencies should we boost the bass/treble/midrange in the tone control circuit of a guitar preamp for best tone?
i read somewhere that the midrange should be between 300hz to 500hz
,,is it true?
Good OL' BeN
tonyharker
If you check out and download the Tone Stack Calculator on this page http://www.duncanamps.com/software.html It may give you some ideas.
Tony.
benzer
yea its a nice program,but the you cant change the resistor/cap values to get better responses,,for example :
the fender response when it boosts the treble there is a gain of -3 db
and when it boosts the bass the gain is about -7db
i would like some resistor/caps values which gives me a gain of almost 0 db at each highest boost,, any idea?
Good OL' BeN
That's the nature of the circuit: It has very high insertion losses. We are talking about a passive circuit so it essentially doesn't boost anything. The "boost" is achieved by attenuating other frequencies.
You can decrease the insertion losses by driving the circuit from a low impedance source, having a high impedance following stage and by decreasing the "sweep" resistor's value. (In "Fender" stack it's R1). You'll have to tweak other values accordingly to maintain proper response. Basically, you scale the circuit to lower impedance. The default values are taken from tube circuits.
However, I think you'll never get rid of the inherent "lossiness" of this circuit (and it's variants) - at least not without seriously decreasing the range of controls or messing up the characteristic response.
The way I see it you have two choices: 1. Convert it to an active circuit or 2. Use another tone control circuit.
Be warned: TSC's "Vox" stack gives invalid results. Duncan Munro has been informed about this issue years ago but so far he has not corrected the errors. I think that particular software is too limited anyways. You can edit component values alright but that's about all you can do. SPICE is soooo much better.
benzer
Quotedecreasing the "sweep" resistor's value. (In "Fender" stack it's R1). You'll have to tweak other values accordingly to maintain proper response.
true but how would i know how to change the other values??
the transfer function for the fender stack is very complicated
Good OL' BeN
You'll have to experiment with that. If you would have read my post more carefully you would have catched the important point: You can't tweak that circuit too much without messing up either the range of controls or the characteristic response.
You may get a fair compromise between frequency response, control range and insertion losses but you can't replicate the "default behaviour" with lesser insertion losses; for that the circuit is just too damn "interactive". If you are not happy with that then try another circuit or convert it to an active one.
benzer
expirementing values using matlab is hard unless you have the transfer funcion.. does SPICE do it easily? and what version are you using?
Good OL' BeN
It is definitely easier with SPICE-based software once you'll learn how to use it. I tried various SPICE softwares few years ago and ended up using LTspice/SwitcherCAD III; it's freeware and very intuitive to use.
http://www.linear.com/designtools/software/#Spice
benzer
thnx 4 the link,, lookslike its got another good softs too
Good OL' BeN
