May 13, 2024, 04:09:16 PM
Fender deluxe 85 frying power transistors
Started by mccutter, January 01, 2024, 03:03:40 PM
If the hum was not present before then a fair chance you have left off a ground connection somewhere. Check continuity from chassis to all common points.
Other possible issue is you have grounded something that should not be grounded and now have a ground loop. Sometimes there are isolation washers under screws that can easy get missed.
