May 08, 2024, 07:25:29 PM
Who has Layout for Mosfet P. Amp?
Started by kikback007, May 20, 2020, 10:49:56 PM
kikback007
Anyone? Im trying to build an amp in new approach. This time by using transistors. Maybe just 50w output is enough.
#1
This is an old design that was in an IR data book in the 80's. It doesn't have short circuit protection, but that can be added. You also need gate protection zeners for the output MOSFETs. I built one and it sounded good. You can get to 50W at 4 Ohms with +/- 25V rails.
Link: http://www.cieri.net/Documenti/Altri%20marchi/International%20Rectifier%20-%20Linear%20Power%20Amplifier%20Using%20Complementary%20HEXFETs%20(AN948).pdf
Edit: Attached below is the PCB layout from the Ap note article edited to show the components X-ray style over the etch.
OK, I looked at the Ap Note and it's hard to follow. On the layout they provided there is no Q1 and two Q3's. The board side view doesn't line up with the component side view. There are also places where you need to add jumper wires that are not shown. So I built a new version and I'll show my layout sketch and the mods I did to the schematic. One additional mod I did was to add a capacitor to the input.
Most things I build are on a proto board with holes on 0.1 inch centers and copper pads on one side. To this I add eyelets from Keystone in three sizes. In some places you need to remove the copper pads because the pads cause shorts between eyelets. There are multiple ground wires that come off the power amp board to a star on the power supply board that I haven't built yet. I built the power amp board and got it running on my lab power supplies. Still might make some changes there. Another mod I allowed for is mixed mode feedback. There is an eyelet on the power amp board labeled IFB. That hooks to a low value resistor that goes between the low side of the speaker and ground. If you just want Voltage feedback, ground the IFB pin.
The attached schematic shows the short circuit protection and zener diodes on the MOSFETs.
kikback007
Thank you. Ill keep these schematics for later builds
This circuit has a temperature compensation problem, as it warms up, the bias current goes lower and lower. I started a discussion of it here: https://www.diyaudio.com/forums/solid-state/355583-class-ab-hexfet-amp-temperature-compensation.html ... but so far no one has responded.
