May 02, 2024, 06:38:59 PM
sound city clean-up
Started by ilyaa, March 10, 2014, 04:46:46 PM
ilyaa
v4 turned ghostly white!
since there is no reverb tank to speak of, if i just pull v4 out and play without a tube in that socket, will the amp be mad?
Quote from: v4 turned ghostly white!v4 turned ghostly white!
A sure sign of an air leak.
When valves are manufactured they are first pumped down with a vacuume pump connected to the seal off point (the top tip in 12AX7's and the like, inside the base with octal types).
They are then sealed off and an induction heater used to "fire" a gas "getter", generally barium, inside the envelope which leaves a silver deposit on the inside of the glass somewhere.  This patch continues to mop up any residual gas that escapes from the assembly during its life.  If the valve gets a gross leak, say around one of the leadouts, or simply by being broken, the remaining barium reacts with the oxygen in the air to form barium oxide which happens to be white.
A pair of 6L6's, a good one in front, a duff one behind.
Note: broken valves should be treated as toxic waste because they contain materials such as barium getters and thorated (radioactive) cathodes.
Quote from: ilyaa on July 03, 2014, 04:49:28 PM
Should be fine, preamp supply voltage will probably come up a little.
ilyaa
roly,
are you saying its a physical issue with the valve itself? another valve in that same socket has done the same thing - what non-physical/mechanical things could cause it?
nashvillebill
Yes, the tube (valve) has lost its integrity physically.  A tiny crack in the glass-- at the base, or around a pin perhaps.
If this is the second one to experience the exact same failure, then I'd look very carefully at the entire mechanical area around the tube.  How is it being inserted, how is it being clamped, is something hitting it or pressing on it.
Quote from: ilyaa on July 04, 2014, 01:04:17 PM
Well it is possible to break a bottle with thermal shock, sudden gross red-plating causing the glass to crack;
(note the white getter in the top)
... but as Bill says, this is basically a mechnical problem (or perhaps a very unlikely co-incidence, they do happen), but I'd be giving the whole area of the valve socket/can/retainer a really good scrute, nothing caught down one of the socket contacts, pins actually going into and not alongside a contact (bent pins), something stressing one of the contacts underneath, ...too much force...?
Nothing, particularly metal, should be tight on the glass (shields excepted of course).
ilyaa
ah yeah i see both tubes that have turned white have a crack in a similar place alongside some of the pins - ill check the socket closely - might be bent in one side putting too much pressure on the glass
