April 25, 2024, 03:19:24 PM
marshall G30R CD clean channel volume problem
Started by lordraptor1, February 06, 2020, 06:22:04 PM
Op amps don't fail making crosstalk, they simply amplify what comes to them.
It really doesn't matter where the controls are on the panel for the most part.  But maybe...
Crosstalk isn't a failure of anything.  Well other than the design.  Crosstalk simply means some part of the circuit is sensitive enough to pick up the signal from some other part.
An example.  Some poorly designed PA mixers, you can plug a hot signal into channel 1 and if you turn up channel 2, some of channel 1 will be leaking into it.  This is because the two channels are close enough together electrically.  it isn't something you can "fix".
