May 21, 2024, 01:40:03 AM
Orange Crush 12 repair
Started by flester, March 26, 2018, 06:10:15 PM
flester
I did break the earth connection to chassis as shown in this photo but am fairly sure the issue was there before that
Sent from my SM-G935F using Tapatalk
flester
Picture now attached
flester
I'm having another go at this as I have a bit of time on my hands. I didn't do anything with the opamp but replaced the gain and overdrive pots and repaired some broken pcb traces. I'm left with the following issues.
1. At low levels, with overdrive at zero, a. Pretty good clean signal with a lot of hiss via internal speaker.
b. Signal disconnects intermittently.
3. At higher levels, signal sort of drops out as the note fades l. Sound clip below
https://drive.google.com/file/d/1k-Kf7-oBOZkOzntB7SPu0VswwtfftZrZ/view?usp=drivesdk
Any ideas? I can show bits of my schematic if I can get it finished
Sent from my SM-A505FN using Tapatalk
flester
Correction:.
1.At low levels, with overdrive at zero, a. Pretty good clean signal with a lot of hiss via internal speaker.
b. Signal disconnects intermittently when using headphones
Quote from: flester on May 13, 2020, 06:12:18 AM
Correction:.
Sounds like an intermittent ground issue.  Go over any solders/connections that go to ground.  Also, sometimes speaker outputs etc don't go direct to ground but rather pass through a 0.1 ohm resistor or similar.  If this is the case, you can cause issues by sending it straight to chassis with an uninsulated jack.
flester
Thanks. I will try those checks.
If it crackles when you wiggle the the Hphone plug then check for cracked solder pads on the PCB at the Hphone socket terminals.
flester
No crackles when I wiggle any of the pots or jacks.
Joe, your mention of ground connections focused me. I think I soldered the overdrive pot, middle leg incorrectly to ground. See before and after photos below. What do you think?
Quote from: flester on May 13, 2020, 12:23:04 PM
Kinda rough soldering job on a few joints there.  I would suggest reheating any joints that don't look clean.  Are you using lead free solder?  If so, turn your heat up.  If not, you still may be running too cold, but just don't turn it up quite as high.
flester
You're right about cleaning up my soldering. Yes, its lead-free solder. And I will continue checking the ground connections.
Quote from: flester on May 14, 2020, 04:44:40 AM
Honestly, I would consider purchasing some leaded solder.  It makes repairs like this WAY easier.  Just wash your hands when done, and no licking the solder.   :dbtu:
flester
Thanks for the tip. I now have some lead solder and it is indeed easier to use.
I decided to use wire links instead of repairing the broken traces and have good connections now. I am left with 2 issues, which I can live with but would be nice to fix if possible. One is that there's still quite a lot of hiss.  Also the overdrive still goes crazy from about half way up, after which I get a very loud low frequency buzz.  While half way is more than enough overdrive for me most of the time,  theres obviously still something wrong.
The pot is new, works smoothly as measures correctly (250K linear). All pots have been cleaned with contact cleaner. Could this point to the opamp or the clipping diodes?
Sent from my Acer Chromebook R13 (CB5-312T) using Tapatalk
Quote from: flester on May 15, 2020, 02:22:10 PM
Sounds like poor grounding to me.  Alternatively, possibly a short between traces as this can cause the gain issue you are having.
