May 12, 2024, 12:00:35 AM
Gallien Krueger 800RB
Started by ilyaa, July 22, 2019, 03:22:39 PM
ilyaa
frustrating issues -
this amp has blown a few woofers - a pair of 10s in a 4x10 and a beefy EV 15 - it blew the 10s after about an hour and a half or so and blew the 15 in under a minute -
problem is, on the bench, it has no measurable issues. no DC on the output - shows me a perfect sine wave at full power on the scope - runs for as long as youd like with no visible problems.
im hesitant to plug it into an actual speaker because i dont wanna blow anything - any ideas what could be happening?
i asked the client about cabs and speaker wiring - the cabs and speaker cables were being used with other amps with no problems.
hmmmm....
Just use a resistive load in place of speaker then you can safely measure the DC on the output.
ilyaa
i am - thats how ive been testing it -
Sorry if i misunderstood that point.
Maybe use different loads like  4 Ohm then try 16 Ohm to see what makes it go crazy DC. I vaguely recall an amp years back that did crazy things ,, but found the Zobel network was burnt open causing strange DC problems.
Replaced and all was good.  Just a thought :-\
The amp may be unstable & is oscillating at a high frequency (above hearing)
A scope should show that.
A beefy EV still might not handle 300W and this amp will do that easily into 4 ohms.
Is he pushing it to clippping?
The fact that it only blew 2 out of 4 tens makes me think over-powering rather than some DC fault.
Autopsies of the voice coils can be instructive.
ilyaa
let me see if i can get my hands on the blown speaks -
how would overpowering vs. a DC fault look differently on a blown voice coil?
A voicecoil overheated from overpowering will be fairly uniformly roasted.
A DC condition will push the coil in or out of the gap, leaving part of the coil exposed.  The exposed part will cook first, leaving part of the coil cooked, and part of it intact.
Others here may have other comments, but that is probably the first thing I would look at as far as the coil.
Quote from: g1 on July 24, 2019, 01:45:22 PM
Agre+1,,, Well explained. :tu:
ilyaa
Finally got my hands on the speaker -
Autopsy results point to DC condition -
https://ibb.co/VjKdSzD
https://ibb.co/9WjmPJ5
https://ibb.co/TR55dgC
Agreed?
If the Amp is testing fine on the bench - any thoughts as to how I'd go about tracking this DC failure down??
Well have you checked the voltages on the schematic?
https://elektrotanya.com/gallien-krueger_800rb_sm.pdf/download.html
If that 5 Ohm resistor at R57 is running hot then I believe that is a sign that there is Hi Freq instability.
What is the DC reading at idle?
Then how much does it drift as you increase power?
I'd haz za guess the issue is early in the signal path.
If C11 is stuffed that may send it into oscillation.
A scope here would be the best way to tell you what is going wrong.
Also don't forget to keep a keen eye on simple things like dried /cracked solder pads.
What G1 said
Failure description + pictures point at gross overpowering.
That Bass Player must LOVE Jack Bruce sound.
- "hey, your Bass is distorting ..."
-" what distortion? ...."
Full rail to rail squarewave all the time.
Probably 500/600 W squarewave from a 300/350W RMS sinewave power.
4 x 10" voicecoils (150W each) stood onslaught for 90 minutes; single EV one (probably oldstyle EVM15L rated 200/250W RMS) stood it "minutes".
I see a failure which wass more commong long ago, not that much today: even before wire to wire glue toasting, whole flatwire block unglued from Kapton former.
Actually epoxy attaches *poorly* to Kapton, too smooth no pores surface and this failure was relatively common; afterwards some mechanically roughened winding area with a process similar to sandblasting (I used fine grain wetordry sanding paper) or chemically etched surface, dramatically improving adherence.
I bet that EV speaker can be reconed with modern aftermarket coils and stand more.
In any case, Bass player is some kind of Terminator, since he blew the 4 x 10" too.
Given his style he needs 2 x 8 ohm 4x10" cabinets  with 8 x 10" 150-200W RMS speakers ... since he is applying constant 500/600W (clipped)  to them.
EDIT: almost forgot.
before moving so much that it actually clipped the wire opening the circuit, that voice coil jumped all over the place, and winding scratched gap walls both scratching enamel which already makes UGLY mechanical nouise, but also allowing wire to wire arcs appear, which spark and produce buzzy sound.
Sound must have been *horrible* but clearly player doesn´t care ... or even notice it.  ::)
Not sure amp is at fault, and quite certain user woild cause same damage with an equivalent power amp, such as a Hartke 3500 or some Ampeg SVT Pro. (the SS ones).
Or one of the small Class D ones, some of which are deadly (say 550W RMS into 4 ohm).
