April 28, 2024, 10:51:05 PM
Marshall 5010 Needs Help
Started by El Scorcho, March 18, 2018, 09:32:21 AM
I see C20 as the negative rail voltage cap for the ic's.
The schematic shows it as 100uf. (not 100p)
Your amp is a different revision that does not match this particular schematic.
Do not try to match up parts to an incorrect version of schematic.
You opened it up to clean it.  I assume that means it was all working well.
Do your cleaning and play it to see if it has any defects.
If it is broken try to find the correct schematic revision.
If you can, post some pictures of the actual circuit board inside.
El Scorcho
It works-It just has an unpleasant sound. Even on the lower gain input there is a cruddy blanket of harsh fuzz wrapped around what would otherwise be a useable tone. Some of the parts seem a bit 'aftermarket'.
El Scorcho
Here's another obvious replacement.
Quote from: El Scorcho on March 21, 2018, 04:09:25 AM
That sounds like crossover distortion the output pair may need rebiasing.
Being a budget model it has no bias trim.
Someone here might know what to alter as I'm not sure.
If you want to establish if it's Xover dist;
at a Clean medium volume just pluck One string  only and let it ring out.
Now with your ear close to speaker listen as the note dies away if there is a fizzy edge on the note then it Xover distortion. Often mistaken for a torn speaker cone.
Phil
Quote from: El Scorcho on March 21, 2018, 04:10:58 AM
The brown goo is glue which is normal.
They often glue large Caps to help stop vibration cracking the solder pads.
and often mistaken for a leaky cap. 8)
El Scorcho
 I hooked everything back up to test it like you suggested,and that's EXACTLY whats happening - no matter which input, no matter how clean I dial it in, I still get that farty speaker-fizz.
El Scorcho
El Scorcho
Ok, I found a Teemuk post about biasing. Looking over the schematic again, I'm wondering if D1 and D2 have something to do with It. That might explain why D2 is missing and D1 has been changed to a small value cap.
Output transistors are biased by TR3 and associated parts.  D1,2 are nowhere near that, they are at the preamp input.
And Enzo is speaking of the schematic you posted, not your amp.
You say you have 2 inputs, the schematic is for an amp that has one.  And the schematic shows a DI out and headphone out, do you have that?
Also having a quick glance at your chassis, I see D3 and D4 which I can't find on the schematic.
So do not trust that schematic, there must be another version for your amp.
Suggest you try contacting Marshall and see if there is another version drawing available.
El Scorcho
Yeah, I have I think the earliest version. The only schematics I can find are dated 1988 to 1990. 2 vertical inputs, but no  DI or headphone out.
I am looking hard for a suitable schematic.  I see the "missing" diodes with the cap in place.  They are near the IC.  How about this idea:  The diodes were originally reverse coupled pair in the IC feedback loop for clipping, and they decided to get rid of them, leaving a cap for stability.  MAybe?  I see the diodes have a + sign at opposite ends.
Look on the underside where the diodes were.  Are the two ends wired in parallel?
Your output transistors have 1982 date codes, if that helps.
El Scorcho
Thanks Enzo! I contacted Marshall about another version of the scematic. They said they have the a schematic, but can't gaurantee what version it is, and will get back to me. I haven't heard anything further. I finally got under the circuit board, and D1 and D2 seem to be linked together.
El Scorcho
The pic isn't the best. What's going on is that ends + and - ends of both D1 and D2 have been jumpered together on the bottom of the board.
