Solid State Amplifiers => Schematics and Layouts => Topic started by: tedsorvino on March 16, 2018, 10:19:12 PM
Title: Carlsbro Glx documentation - pre amp problem
Post by: tedsorvino on March 16, 2018, 10:19:12 PM
Hi. I'm using an old Carlsbro Glx 80 for about 20 years now.
It's well maintained but suddenly the preamp section on both channels went really weak (I checked the other sections - power amp in, effect send- and they work fine) .
I can't figure out what could have gone wrong since all the mechanical parts work ok....Leads, pots, etc. .
I 'm not sure how it is constructed so I'm looking for any relevant or specific documentation (service maual, schematics etc.) of any model of the Carlsbro GLX series- especially something close to this one.
Thanks in advance
Title: Re: Carlsbro Glx documentation - pre amp problem
Post by: phatt on March 16, 2018, 11:26:34 PM
Before you open it up,,,Try bridging the FX Send and Power amp in with a lead.
If that fixes the issue then the switch inside the socket is likely dirty.
Options;
1/ You can spray electrical cleaner into the socket and insert/remove a plug a few times might fix it.
2/ Replace the socket,, which is likely fiddly if you are not familiar with working on electrical gear.
Or 3/ (my favorite) Get a short jumper lead and leave it connected to the loop.
Post by: tedsorvino on March 17, 2018, 12:03:42 AM
Thanks for the advice Phatt. I m quite familiar with electronic projects and i ve already opened the box. Done it several times actually. I ve tried the patch trick...but to no good results.
Post by: phatt on March 17, 2018, 08:55:48 AM
Check the supply voltages all the way through to the preamp,, see if you are getting voltage at pins of opamps.
Post by: tedsorvino on March 17, 2018, 03:55:13 PM
Will do Phatt. The thing is I ve got no idea what the optimum voltages are in general. Usually op amps have half of the supply on most pins. Am i right?
Post by: phatt on March 18, 2018, 04:40:44 AM
Most common is dual opamps which have pin 4 and 8 for supply.
Post by: g1 on March 19, 2018, 02:27:10 PM
Half of supply on ins and outs with single ended supply.
With +/- split supply there will be zero volts on ins and outs (unless a DC application).
