December 04, 2023, 07:00:38 AM
saturated's all encompassing inclusive and exclusive bin thread
Started by saturated, September 10, 2023, 03:09:27 PM
Tassieviking
The biggest fault with dishwashers is that something small gets in the drain pump and jams the impeller, just remove the item and it's all good.
The second biggest fault is that someone uses normal dishwashing detergent in them and they over suds and then overflow, this causes a small float switch under the machine to cut the machine out, and usually the drain pump runs all the time.
This happens a lot when people have had a party and some good samaritan decides to load the dishwasher and start it for you.
The best way to kill the bubbles is to add some hair conditioner into the machine, it works really fast and that's what most Hotels do.
I once did a house call and found the drain pump blocked, I stuck my hand into the dirty water and I pulled a used hypodermic needle out of the drain pump. I was not impressed.
Another time I stuck my hand into the dirty water and found they had filled it up with hydrochloric acid to try to unblock the machine, that burnt.
saturated
pretty interesting
I think in my case some broken glass put the impeller in a bind and so the pump motor burned up
I tried bringing home washers and dryers for a while and fixing and selling but i guess the mentality is different these days
nobody wants a bulletproof roper or kenmore that will last forever....
oh well rant over
while I got you here I am really struggling with trying to understand how to be safe with oscilloscope grounding.
I was going to put a two prong adapter on the cord to unground it but maybe that is not a good idea.
I dont plan on working on any old tube amps or crazy vintage receivers anytime soon.
I will continue to try and learn how to keep my work safe.
thanks for your help.
I ask stupid questions
and make stupid mistakes
saturated
I was watching a video on my tv and took a pic of the screen
anybody recognize these guys  :P
Tassieviking
[/quote]
It has been a long time since I used my scope, and my scope is a real CRO.
I usually use one ground clamp that I attach to the 0v rail, as long as the 0v rail is grounded.
All my probes have a removable ground wire so all I am left with is the probe itself, I leave one probe with the ground wire attached.
My old "cathode ray oscilloscope" is nothing like the modern units most people have today, turn it on, have a cupper, use it.
nosaj
I tried to post earlier. Do you want a working variac? If so PM for details.
nosaj
nosaj
saturated
that looks pretty nice
thanks for the offer let me read up on them and see if I can use it
saturated
btw i brought home a new volt meter
supposed to be real accurate
yes it needs a nice hot bath
and a power cord...no need for the dbt
my limited google indicates possibly it is a kelvin varley divider etc
there is a youtube video of a fluke 881a in action
will be fun to replace the power cord and see if its even close
saturated
on my to do list...need to build a curve tracer and connect to my oscilloscope
either that or find a tek 575  ::)
saturated
alright i wanted to test my new voltmeter
so first task was unsoldering the disintegrating power cord
which wasnt easy
hot from transformer
ground from fuse holder
and green....common?
and the disconnected carcass
this is a lot of work but oh well i guess its good practice
gonna be all for naught if i get a new cord on there and it fails dbt
because at that point im stopping
also i am discouraged to see silver metal transistors...to me that means germanium...but idk i have no idea
saturated
so i wired up the replacement power cord..which wasnt looking so great either  ::)
no matter how far back i peeled back the outside sheathing the insulation on the interior wires was crumbling
but it appeared the white insulation was more robust...so i went with it
also the wierd lookin fuse was blown
i do not have anything that remotely resembles this
so based on the markings i scared up a plain ol 1/4 amp fuse and stuck it in
next up connected my UDBT (ugly dbt)
powered up...turned it on and all was eerily quiet
I thought well something is open somewhere...this is too good to be true...was fixing to disconnect everything and to my astonishment saw a light on
so i guess my next move is to input a known voltage and then try to rotate the bottom knobs until it matches up....
saturated
i tried it out for a while but didnt get too far
amazingly all 4 lights at the bottom work
its def responding...if i turn the second digit to zero the meter deflects
and back to one which i presume is ten....it goes back
oh well that was fun
time to catch the rest of some football
Tassieviking
#28
Quote from: saturated on October 01, 2023, 02:52:19 PMon my to do list...need to build a curve tracer and connect to my oscilloscope
I don't know if you have a transistor tester yet, but a modern one can be a great item to have, for very little money you can pick up something that can do some amazing measurements on components.
I bought one several years ago but I think I need a new better one as they get better so fast.
I bought one without a case but then ended up buying a case many years later so the final cost was the same as one with a case in the first place.
The old one I have now is in this video on you-tube, the one on the right.
It would be worth spending some time and finding a very cheap one that can do everything the more expensive ones can do, just have to keep looking till you find one.
https://www.youtube.com/watch?v=-pEmM0Kt2UY
Cheers
Mick
 PS...If you find a great cheap one ....let us know :)
