May 12, 2024, 03:46:57 AM
Mashall MG15CDR just went up in smoke!
Started by charliefarley96, June 02, 2010, 07:41:22 AM
Quote from: balaboo on July 06, 2010, 09:50:29 AM
No need to worry - the chip IS bolted directly to the heatsink, which is left UNCONNECTED to any wiring traces on the pcb. I just use regular white lithium grease - works great.
Have you verifyed that the Hsink is indeed *ground isolated* with a Continuity test?
balaboo
Yes, and you can flip the PCB and verify that the heatsink solder pads don't connect to anything - check for swarf, etc.
No that is *only a visual inspection* :trouble
You need a DMM on the Hsink and the other end to CT of PSU
