May 21, 2024, 04:51:01 PM
Peavey XXL repair!
Started by ohmy!!, August 04, 2010, 04:43:30 PM
bry melvin
#45
I'd keep the heritage...It has one trick that a lot of people never think of...you can freeze the sweep of the phaser at a particular spot . I use that on stage to mimic a strat quack when I'm using a 335 or LP instead of changing guitars.
It's a versatile piece of equipment and has been my backup for a long time. I also use it's power amp via the DI output on my 50 Watt JCM sometimes for outside venues for extra push. (through 2 old Sunn Beta cabs)
mix and match time :D
ohmy!!
Yeah the sweep on the phaser is what makes the heritage amp special, a lot of people won't play it without it.  I was running the XXL preamp through the poweramp on it. It doesn't really match that well with it though (when you crank it loud its not bad), I think the XXL sounds better with its own poweramp now that I'm using it.
