June 02, 2024, 06:37:03 PM
Push-Pull Amps
Started by SECONDandBOWERY, June 03, 2006, 12:50:39 AM
el mo
well, the gimmick is that, as far as i know, you can't bridge two amps that have partial current
feedback implemented. so i was wondering if it could work like this.( the obvious method would be paralleling them, i guess )
You can parallel or bridge LM3886 chips, it just depends on what ohm speaker you want to run.
SECONDandBOWERY
Running the input into one op-amp's + inupt and to the other op-amp's - input will put the signals out of phase, correct?
Rock'n'Roll,
--Andy
el mo
QuoteRunning the input into one op-amp's + inupt and to the other op-amp's - input will put the signals out of phase, correct?
-basically  yes, but the op-amp needs to be biased slightly differently, depending on whether the+ or -input is used. so the regular approach is to use a phase-inverter to make the
actual halves of the bridge as identical as possible.
SECONDandBOWERY
Oh, ok.  I'm just going out of the .pdf file that teemuk posted.
Rock'n'Roll,
--Andy
SECONDandBOWERY
Will the schematic I've posted along with this post work as a unity gain phase inverter?  Would I ever need to apply power to the dual opamp, or since it's unity gain, could I just use it as a passive phase inveter?
Sorry if those are stupid questions, I guess i just got used to seeing 12AX7 long tailed phase inverters in tube amps that when I think "phase inveter", that's the only thing that pops into my head!  :duh
Rock'n'Roll,
--Andy
el mo
yes, i guess it would have to work, although you could omit the noninverting system- it doesn't amplify anything and the phase is the same as at the input.
you need to suplly power to the opamp though, ptherwise it won't do a thing.
el mo
there may still be some merit to using a dual opamp, under certain circumstances, for example if you decided that you wanted an arrangement similar to the PI of a tube amp in order to reproduce certain characteristics like voicing etc.
