May 07, 2024, 03:00:22 PM
Fet version of Marshall Superlead Plexi
Started by KMG, January 21, 2011, 05:04:47 PM
Thanks for the crarification,   Tis all good then, :tu:.
KMG
QuotePerhaps can you post some sample sound of it?
At this point still only reamping samples
Clean 9.9M
http://milas.spb.ru/~kmg/files/projects/slp/reamp/Clean.mp3
Clean wih DRE AL3201 (hardwood studio effect) 10.0M
http://milas.spb.ru/~kmg/files/projects/slp/reamp/CleanR.mp3
Drive 12.6M
http://milas.spb.ru/~kmg/files/projects/slp/reamp/Drive.mp3
polo16mi
Yes!!!! I like it!!!  Very cool sound!!!  :tu: :tu: :tu:
Maybe i´ll copy and paste!!!!
Excellent tones coming from that circuit.  Who needs tubes anyway?
QuoteExcellent tones coming from that circuit.  Who needs tubes anyway?
Amen.
Besides, that's the Forum's idea, isn't it? :tu: :tu:
rowdy_riemer
Quote from: J M Fahey on February 04, 2011, 09:46:27 AM
Amen.
It wasn't originally, but it is a wonderful outcome that has just started and hopefully continues to thrive.  No point is using inefficient (lots of watts go to the heater and not the speaker) tubes that are getting harder and harder to come by since they aren't being manufactured by many places when you can have a much more efficient and great sounding FET device.  I love it!
KMG
Quote from: KMG on February 04, 2011, 11:30:55 AM
Two short samples with tube screamer in front (at first part of each file TS is bypassed for reference)
Neck
http://milas.spb.ru/~kmg/files/projects/slp/reamp/BoostNeck.mp3
Bridge
http://milas.spb.ru/~kmg/files/projects/slp/reamp/BoostBridge.mp3
I can't believe the metal tone coming out of it on the bridge pickup with the TS on!  That seriously rocks!
THChrist
Sounds amazing! The schemo OTOH looks like a mace...
THChrist
s#it! i always confuse those. which one is where you put mice in?
Maze: labyrinth
Mace: something to break walls, stone, or your head. Also "tear gas"
THChrist
Quote from: J M Fahey on February 05, 2011, 02:55:02 PM
Maze: labyrinth
Well, that schemo broke my head...
I was used to the typical 2k7/680n, 820/680n, stuff like that. Now I don't see any of these values anywhere (same thing goes for the JCM800. What if I want to add an extra cap? Like a 680n in parallel with 820r before the tonestack? I'm lost.
KMG
Each stage of preamplifiers was designed with the help of this "test equipment".
Right part is the tube version of the stage with input and output interstage circuits.
At the FET part, I first set up the gain below the cathode circuit cutoff frequency of the tube stage by adjusting the resistor at the FET source (adjusting biasing voltage at the same time to keep operating point).
After this I added a correcting RC circuit at the FET source to adjust gain above  the cathode circuit cutoff frequency of the tube stage. R define gain, RC define cutoff frequency.
Frequency response i checked by "RightMark Audio Analyzer".
Thats why you don`t see original values of components in source networks.
The last thing I adjusted the parameters of the "scalable diode" part to provide adequate "grid" limitation.
