dspic-codec
Started by jfetter, December 23, 2011, 12:50:48 PM
jfetter
I finally got the dspic preamp board done. Is any one else doing 16bit (_Q15) dsp?
It sounds great with no noise whatsoever. Running three filters now low,mid,hi.
Not much on the internet or from Microchip on pro-audio apps. Some of the old Analog Devices code works. The 16 bit works great for this app.
I need a good integer q15 reverb and a soft limiter.
This board is not a finished gadget. It is only for developing dsp code. Has six control voltages. Audio path is 100% digital.
Congratulations. :dbtu: :dbtu:
Neat, I haven't done anything with digital signal processing at all yet and I'm thinking about getting into it once my son gets a little older and I have more time.  Any sound clips?  What are your plans for this?  Also, is this a board you designed?
jfetter
Only plans are a pedal or head, maybe a combo. (I want to have something ready for production when the cheap imports go away). I will try to get a clip posted this weekend. Lost three days troubleshooting a nasty sound on one string. Turned out to be my headphone amp. I could not see it on scope so should have known. I'm now working on the WET-DRY mix having a lot of fun with it.
Its using the dspic33fj256gp710, wolfson WM8731 and/or ti TLV320AIC codec. I have 4gb sd flash card for reverb tank. The flash should last several years with leveling(see microsoft "readyboost" http://blogs.msdn.com/b/tomarcher/archive/2006/04/14/576548.aspx ). DMA is utilized with the codec so processor has about 20% loading. The circuit itself is pretty simple. The codec takes care of anti-alias.
Schematic attached..
As mentioned I now do all work on OSX
Quote from: jfetter on December 29, 2011, 09:24:39 PM
You're going to be waiting a while...
Agree.
Go ahead anyway, make your thing, and when ready try to sell it.
If the product really stands above the rest, or offers something others don´t, then you have what´s called your "selling point".
Meaning: you must be able to answer (truthfully) the Customer´s question: "why would I buy *yours* instead of something else?"
You must be able to provide a meaningful answer, or you won´t sell, imports or not.
jfetter
I!m bettin devaluation of usd very soon. Getting speakers will be a problem so a head is probably the way to go.
Quote from: jfetter on December 30, 2011, 03:36:41 PM
How is devaluation of the USD going to help get rid of imports?
Well, it will make them more expensive.
Problem is, with China minimum wages of U$ 0.39 an hour (official data for "foreign" (read=US capital) in the Shanghai area) anything they make will still be impossibly cheap.
An example:
http://youtu.be/W_YnaHNcISw
Anyway, study and experiment a lot and develop something which can´t be made by the millions by slaves and you´ll have a chance to sell.
jfetter
Here is an example of a one knob super tone control. aka STONE control...
The control voltage is reduced to 64 discrete points and the tone MACs use the multipliers as "gain" for lo mid and hi. The center position gives an enormous scoop. It sounds very musical.
Adjustments can be made for LOW and HI too. What I like is the soldering iron is never plugged in.
volatile fractional STONE[64][3]={
    {Q15(0.570),  Q15(0.1),   Q15(0.235)},   //00
    {Q15(0.560),  Q15(0.1),   Q15(0.205)},   //01
    {Q15(0.545),  Q15(0.1),   Q15(0.195)},   //02
    {Q15(0.540),  Q15(0.1),   Q15(0.175)},   //03
    {Q15(0.535),  Q15(0.1),   Q15(0.165)},   //04
    {Q15(0.530),  Q15(0.1),   Q15(0.170)},   //05
    {Q15(0.525),  Q15(0.1),   Q15(0.175)},   //06
    {Q15(0.520),  Q15(0.1),   Q15(0.180)},   //07
    {Q15(0.515),  Q15(0.1),   Q15(0.185)},   //08
    {Q15(0.510),  Q15(0.1),   Q15(0.190)},   //09
    {Q15(0.505),  Q15(0.1),   Q15(0.195)},   //10
    {Q15(0.500),  Q15(0.1),   Q15(0.200)},   //11
    {Q15(0.495),  Q15(0.1),   Q15(0.205)},   //12
    {Q15(0.490),  Q15(0.1),   Q15(0.210)},   //13
    {Q15(0.485),  Q15(0.1),   Q15(0.215)},   //14
    {Q15(0.480),  Q15(0.1),   Q15(0.220)},   //15
    {Q15(0.475),  Q15(0.1),   Q15(0.225)},   //00
    {Q15(0.470),  Q15(0.1),   Q15(0.230)},   //01
    {Q15(0.465),  Q15(0.1),   Q15(0.235)},   //02
    {Q15(0.460),  Q15(0.1),   Q15(0.240)},   //03
    {Q15(0.455),  Q15(0.1),   Q15(0.245)},   //04
    {Q15(0.450),  Q15(0.1),   Q15(0.250)},   //05
    {Q15(0.445),  Q15(0.1),   Q15(0.255)},   //06
    {Q15(0.440),  Q15(0.1),   Q15(0.260)},   //07
    {Q15(0.435),  Q15(0.1),   Q15(0.265)},   //08
    {Q15(0.430),  Q15(0.1),   Q15(0.270)},   //09
    {Q15(0.425),  Q15(0.05),   Q15(0.275)},   //10
    {Q15(0.420),  Q15(0.05),   Q15(0.280)},   //11
    {Q15(0.415),  Q15(0.025),   Q15(0.285)},   //12
    {Q15(0.410),  Q15(0.025),   Q15(0.290)},   //13
    {Q15(0.405),  Q15(0.001),   Q15(0.295)},   //14
    {Q15(0.400),  Q15(0.001),   Q15(0.300)},   //15
    {Q15(0.395),  Q15(0.001),   Q15(0.305)},   //00 mid
    {Q15(0.390),  Q15(0.001),   Q15(0.310)},   //01
    {Q15(0.385),  Q15(0.025),   Q15(0.315)},   //02
    {Q15(0.380),  Q15(0.025),   Q15(0.320)},   //03
    {Q15(0.375),  Q15(0.05),   Q15(0.325)},   //04
    {Q15(0.370),  Q15(0.05),   Q15(0.330)},   //05
    {Q15(0.365),  Q15(0.1),   Q15(0.335)},   //06
    {Q15(0.360),  Q15(0.1),   Q15(0.340)},   //07
    {Q15(0.355),  Q15(0.1),   Q15(0.345)},   //08
    {Q15(0.350),  Q15(0.1),   Q15(0.350)},   //09
    {Q15(0.345),  Q15(0.1),   Q15(0.355)},   //10
    {Q15(0.340),  Q15(0.1),   Q15(0.360)},   //11
    {Q15(0.335),  Q15(0.1),   Q15(0.365)},   //12
    {Q15(0.330),  Q15(0.1),   Q15(0.370)},   //13
    {Q15(0.325),  Q15(0.1),   Q15(0.375)},   //14
    {Q15(0.320),  Q15(0.1),   Q15(0.380)},   //15
    {Q15(0.315),  Q15(0.1),   Q15(0.385)},   //00
    {Q15(0.310),  Q15(0.1),   Q15(0.390)},   //01
    {Q15(0.305),  Q15(0.1),   Q15(0.395)},   //02
    {Q15(0.300),  Q15(0.1),   Q15(0.400)},   //03
    {Q15(0.295),  Q15(0.1),   Q15(0.405)},   //04
    {Q15(0.290),  Q15(0.1),   Q15(0.410)},   //05
    {Q15(0.285),  Q15(0.1),   Q15(0.415)},   //06
    {Q15(0.280),  Q15(0.1),   Q15(0.420)},   //07
    {Q15(0.275),  Q15(0.1),   Q15(0.425)},   //08
    {Q15(0.270),  Q15(0.1),   Q15(0.430)},   //09
    {Q15(0.265),  Q15(0.1),   Q15(0.435)},   //10
    {Q15(0.260),  Q15(0.1),   Q15(0.440)},   //11
    {Q15(0.275),  Q15(0.1),   Q15(0.445)},   //12
    {Q15(0.285),  Q15(0.1),   Q15(0.460)},   //13
    {Q15(0.295),  Q15(0.1),   Q15(0.470)},   //14
    {Q15(0.325),  Q15(0.1),   Q15(0.480)}   //15    16 X 4=64
then in the DMA handler
// do the macs
        for(i=0; i<16;i++){
        ACMA = __builtin_clr();
        ACMA = __builtin_mac(ACMA,LOW, lowpassout, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL);
        ACMA = __builtin_mac(ACMA,MID, midpassout, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL);
        ACMA = __builtin_mac(ACMA,HI, hipassout, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL);
        sumadd = __builtin_sacr(ACMA,-3);
Cool !!!
Now I´ll type it in my Commodore 64 and will give it a try. ;)
Bad jokes aside, congratulationson your experimenting.  :tu:
Now we need some MP3s showing the results ;)
Cool  :tu:
As a programmer, I applaud the effort!  Now if only there was a way to use PHP in stompboxes...
jfetter
My last entry on this thread was 2011.
So and update is in order. I retired ( if that even exists) in 2015 and although love the signal processors, have gone all analog target designs.
My 100% push since 2016 has been low voltage tube-ss hybrids.
I generally use the tube in fb loop with op-amp and have learned a lot along the way.
Pentodes and triodes work just fine at 30v potential (+-15VDC). No positive grid drive is used.
My test equipment is upgraded now with Motu M4 for spectra analysis. New scope and linear bench power supplies too.
For power amp I use the tpa3118 almost 100%.
Maybe one day re-visit the dspic32 but having too much fun all analog.
Hot on to do list is re-visit Germanium. Maybe an all discrete tube-Germanium hybrid will materialize.
-cheers
Quote from: jfetter on April 09, 2020, 03:30:16 PM
-cheers
Sounds like fun, I'd love to see pics and/or videos of the hybrid stuff you've come up with!
