May 10, 2024, 04:52:26 PM
help building ESP Project 27 power amp
Started by el nino, July 22, 2012, 05:55:23 PM
el nino
hi guys, i'm planing to build an ESP Project 27 power amp, can i power it with DC -+25volt and 2 ampere trafo? How much watt power can i got from it? Thank's
my guitar want's to kill your father
el nino
thank you sir, i found this layout from google...
Can i use it? Or its need some mod?
It's very kind if you check it, if you dont mind... Thank's again sir
Really don't know, ask Rod Elliott himself.
Obviously the origiunal PCB works without problems and probably comes with assembly instructions.
