May 16, 2024, 01:48:48 AM
TL071 pre amp from "the Guitar Handbook"
Started by critter01, January 19, 2009, 09:39:55 PM
critter01
Hi Guys,one of threads in this forum discussed improving the design of this preamp,apparently there were some problems with the original design.as i am about to attempt building one of these,can someone please explain what the problems were and what has been done to "improve" this preamp. ???cheers guys i look forward to your replies.
critter01
Awww!! come on guys, some one must be able help me??? PLEASE  !!!.cheers.
Hi Critter, please post the link (or at least the schematic).
Thanks
critter01
SSGuitar Friend
Chip Points: 0
     Improved 'Guitar Handbook' TL071 preamp
« on: September 12, 2007, 07:55:09 AM » Quote
I have had a go at redesigning the circuit using the TI single supply handbook.
It avoids most of the pitfalls of the original though i am not expert.
If anyone in the know can comment that would be good.
I will try it with both a TL071 and a OPA134.
The OPA134 should sound better since it is a very high spec opamp btu you never know!
critter01
http://www.ssguitar.com/index.php?topic=562.msg3915#msg3915
:loco sorry guys - heres the link to the thread i was refering to.(hope this works) looking forward to your replies.cheers
armstrom
It's been a while since I've read that thread but without going back and re-reading it all I believe the improvements were as follows:
-increased input impedance and reduce noise by using a separate voltage divider network to generate the bias voltage and then use a higher impedance resistor to reference the non-inverting input to the bias voltage
-additional power supply filtering
There are probably other improvements that's I'm missing, but those are the ones that stand-out in my memory.
Keep in mind that the schematic attached to the first post of that thread is not "the most improved" design that is presented in the thread. Based on discussions within the thread the design was further refined and updated schematics were presented.
