Solid State Amplifiers => The Newcomer's Forum => Topic started by: flester on December 20, 2017, 04:11:47 AM
Title: First real build. LM386.
Post by: flester on December 20, 2017, 04:11:47 AM
I mentioned this in other posts but heres a rundown as a novice on my LM386 build. I call it the Bearskin amp. Its a veroboard project very similar to the Little Gem , Ruby, and Smokey amps. No internal speaker. 1K gain pot plus a IK volume control on the output side.
Overall very pleased with this build. The only issue is the volume pot. It is linear slope but still seems more loggy if u know what I mean. Admittedly the quality of the pot is not great but maybe I need a different resistance or slope?
Sent from my SM-G935F using Tapatalk
Title: Re: First real build. LM386.
Post by: flester on December 20, 2017, 04:19:50 AM
Since taking these photos I glued sheets of pickguard inside to provide support for the pots and jacks as the walls are rather thin. Also sub mini toggle switch in between the pots.
Post by: Katoda on December 20, 2017, 11:30:15 AM
Cool, congrats!
The gain and volume pots are supposed to be logarithmic, if yours are linear, then they probably have an exponential curve effect to the ear, as we percieve the power vs volume logarithmically. You can simulate the log response by putting a resistor from the wiper to tje ground, but then you need a bigger pot or to decrease the impedance going into the pot.
Glad to see it works, cheers.
Post by: flester on December 21, 2017, 09:47:39 AM
Quote from: Katoda on December 20, 2017, 11:30:15 AM
Cool, congrats!
Thanks I might try that. Just used the pots I had so I knew they might not be right. 1k lin was recommended for the gain but the vol specified 25ohm. (Ruby Amp project on generalguitargadgets.com). Certainly getting great enjoyment from the project and looking forward to playing it
Post by: flester on December 31, 2017, 09:21:57 AM
Quote from: flester on December 21, 2017, 09:47:39 AM
Cool, congrats!
I tried making a few changes and basically all the 1k pots disintegrated from too much soldering and de soldering. So ended up with 10k linear for gain and no vol pot. Gain does nothing from 0 to 9 then it all happens between 9 and 10 so look likes i need a log pot. Any good suppliers or brands i should look for?
Post by: Katoda on December 31, 2017, 11:26:24 AM
Doesn't really matter what brand you use. But before you order a new pot, you might want to try soldering a 1.5k resistor from wiper to ground, which will somewhat simulate the log curve.
Post by: flester on January 02, 2018, 07:29:40 AM
Quote from: Katoda on December 31, 2017, 11:26:24 AM
Onlt asking about brands as the ones I got were trash. I think 10k is too much for the gain as its in parallel to a 1.35k res within thw chip. It works more like a high/low gain switch than a pot
Post by: Katoda on January 02, 2018, 08:37:37 AM
Oh right, sorry, I wasn't looking at the schematic, didn't see that the gain control was actually feedback control. For that configuration you might need an anti-log pot. Also, datasheet specifies you should use a capacitor in series with the pot, but that's not really the problem.
For the pots - I usually use Alpha brand, they're cheap and of all-right quality.
Sorry I couldn't be of more help, good luck.
Post by: flester on January 03, 2018, 04:32:52 PM
Quote from: Katoda on January 02, 2018, 08:37:37 AM
Today i added a DC jack to use a 12v supply or the 9v battery. 12v fattens and cleans up the sound nicely at minimum gain. Also  screwed the board in place and used hot glue here and there so nothing moves that shouldnt.
Im guessing any 1k pot would be an improvement but will try antilog and also linear.
Now planning MkII. Will post final schematic and sound samples in due course
Post by: flester on January 11, 2018, 03:27:12 PM
Quote from: flester on January 03, 2018, 04:32:52 PM
Heres a video with my lap steel
https://flic.kr/p/23otDrP
Post by: phatt on January 12, 2018, 08:14:07 AM
Hey some nice blues riff there :tu:
BTW, looks like you are driving a hifi type speaker box,, if so then be aware they are woofers and generally have a low SPL,, a real guitar speaker will give a much bigger sound,, louder per watt of input.
Post by: flester on January 16, 2018, 02:10:25 PM
Quote from: phatt on January 12, 2018, 08:14:07 AM
A friend has a 12" guitar speaker I can use. Time for a bit of joinery I think
Post by: flester on January 23, 2018, 06:24:42 AM
Quote from: flester on January 16, 2018, 02:10:25 PM
Works as a harmonica amp too. I made the mic using a headphone speaker. The black box on the right contains a Kemo preamp module, needed to overdrive the amp. A Danelectro overdrive pedal works too. https://flic.kr/p/22mhiVv
Post by: flester on January 31, 2018, 07:28:17 AM
Thinking about the speaker, I want to use a combo as a cab. Very useful for testing all kinds of amp projects. What type of jack will disconnect the internal amp when an input is plugged in. Been searching 'switched jack' but that doesnt seem to cover what I want.
Post by: Katoda on January 31, 2018, 09:26:57 AM
A jack like this one, but a mono version. Or stereo, doesn't matter. Plastic 6.3 mm jack
Post by: flester on January 31, 2018, 10:12:02 AM
Quote from: Katoda on January 31, 2018, 09:26:57 AM
What is it called?
Post by: Katoda on January 31, 2018, 11:23:15 AM
It is just a plastic jack, no need for a name. You get these mostly everywhere they sell components, from Ali to Farnell and everything in between.
Post by: g1 on January 31, 2018, 08:50:10 PM
They are sometimes called 'Cliff style' but that is a brand name.  Maybe 'leaf' style?
Neutrik NMJ4HF-S would be an example.
Post by: flester on March 23, 2018, 09:07:55 AM
Quote from: flester on January 23, 2018, 06:24:42 AM
Amp seems to have got more 'scratchy' since I first used it. Usually if I slightly overdrive it but its OK when I run it flat out (i.e. give it the full 0.75W !). Could some component have deteriorated  from being overdriven? or did I just not notice at the start?
Post by: flester on April 08, 2018, 05:22:45 PM
Quote from: g1 on January 31, 2018, 08:50:10 PM
I meant to ask about the switching part. I want it to switch off the speaker when a plug is plugged in. Is it just called a switched jack?
Post by: flester on January 05, 2019, 05:26:04 PM
Finally did the joinery ( takes me a while to do stuff!) I now have the amp and some pedals powered by a single PS in a case and going in to the 1x12. Plenty loud for home use and a great platform for bigger amp builds.
Speaker good for up tp 80w.
1w amp and pedals into 1x12 cab
https://imgur.com/gallery/lKMg7CR
Post by: phatt on January 07, 2019, 12:33:09 PM
Quote from: flester on April 08, 2018, 05:22:45 PM
Yes very common switched socket,, the plastic ones lift the connection when you insert a plug. there is a pic at top of page.
Post by: phatt on January 07, 2019, 12:36:45 PM
Quote from: flester on January 05, 2019, 05:26:04 PM
Yes a real guitar speaker makes a much better sound. 8|
Post by: phatt on January 07, 2019, 12:39:44 PM
Quote from: flester on March 23, 2018, 09:07:55 AM
If you changed the speaker then you will hear different freq than you heard through other speakers. It was likely there you just did not notice it.
