Solid State Amplifiers => Honey Amp => Topic started by: mckayprod on July 28, 2021, 11:21:32 AM
Title: Thoughts on my new Honey Amp
Post by: mckayprod on July 28, 2021, 11:21:32 AM
I just built mine over the weekend, and I want to start by saying "thanks" for adding a project to all the conversations and information on the forum.  This is a good way to bring it all together and stimulate more discussion.
Next, stuff I like: Excellent board, quality components...real pro stuff and I appreciate that. The distortion sound is smoother than I expected, especially on the higher-gain end of the tone range. The tone control mellows out any fizziness which could be a problem depending on your guitar/headphones/speaker.
And, my criticisms: Too much distortion, and not enough volume with the gain turned down to the edge of breakup.  I'll modify it to the clean buffer preamp option one of these days. No power switch, but I can understand the omission, since this is supposed to be highly customizable. I have to pop the battery connectors to power down, but my enclosure choice makes that easy enough. Finally, what can you say about the lack of volume from a LM386 that hasn't been said before?  I'm running two 9v in series for +18-ish volts, and this is sufficient for headphones, but just.  I haven't tried a speaker yet.
That's my experience, and I look forward to more SSGuitar projects and discussions!
Title: Re: Thoughts on my new Honey Amp
Post by: Jazz P Bass on July 28, 2021, 11:45:33 AM
" No power switch, but I can understand the omission, since this is supposed to be highly customizable. I have to pop the battery connectors to power down, but my enclosure choice makes that easy enough"
You could try a 3 prong switching jack that disconnects the battery ground when no cord is inserted.
Like pedals use.
Post by: joecool85 on July 31, 2021, 09:13:33 PM
Like pedals use.
Or just wire a switch inline with the battery - that's what I do.  I'm not a fan of onboard power switching, even when it is for a battery amp.
Regarding power output, it is an LM386 so it's about as loud as I could get it.  If you need more headphone volume, try using a lower resistance value for R10.  If you use 10 ohm it should just about blow your ear drums with any normal headphones - mine certainly did!
I'm planning another battery based kit, probably power amp only.  This one would be based on the PAM8302 which gives 2.5w and runs on a really low voltage of 5v nominal.  I've been playing with the board from Adafruit and it's significantly louder than any LM386 circuit I've used.
Post by: argenta on August 02, 2021, 06:05:35 AM
Hi there, I am interested in the Honey Amp kit. Where can I purchase please?
Cheers
Rhea
Post by: joecool85 on August 02, 2021, 11:41:07 AM
Cheers
Rhea
Argenta,
I'll be adding a web store soon to the site so you can purchase there.  If you'd like one sooner than that, please PM me and we can do a direct sale.
Post by: joecool85 on August 05, 2021, 03:48:15 PM
Cheers
Rhea
PM Sent.
Post by: mckayprod on August 12, 2021, 06:19:13 PM
Quote
Looking forward to this one.  2.5w is about all I'd need with a speaker.  Consider a basic preamp board to go with it.  Thanks again!
