May 13, 2024, 08:24:54 PM
Joe Davisson's new Guitar amp
Quote from: Joe on August 16, 2009, 09:45:36 PM
Thought I would try it this way, since the transformers are from RS, and only $10 a piece. Also, I think it will bump the output some.
Let me know how it works out.  I've thought about using the same setup with those transformers for a LM3886 project.
Joe
Put another pic up of the board/heatsink. Just a layout, will solder the parts this weekend. You can see the protection circuit on the right-hand side.
http://www.diystompboxes.com/analogalchemy/sch/dc_wip.html
Quote from: Joe on August 22, 2009, 12:55:22 AM
That looks great!  Good job, Joe!
Joe
#63
I tested the amp today, although it's sorta tacked together at the moment and not at all pretty. I designed it to be compatible with a pedal circuit, so that's what I used for a preamp. Sounded pretty good distorted, but I still need to run a clean tone and see how that works out.
My NPN and PNP transistors were mismatched, so there was about 2V offset. I adjusted one of the emitter resistors on the first stage to compensate, but I really think all complementary pairs need to be matched. (Not all the transistors, just each NPN/PNP pair.)
The power supply uses the two radio shack transformers, two bridge rectifiers wired in series, and two 4700uF filter caps & some bleeder resistors.
Edit: Tested the short circuit protection with a screwdriver across the speaker leads, and it works good. Did a little more play testing and am happy with the sound. So it's a matter of wiring some things nicer and tweaking the bias a little.
Quote from: Joe on August 24, 2009, 03:55:02 PM
You should enter this one in the contest!  Also, once you get it a little more finished I would love to hear a clip or two.
Brymus
Radio Shack is gonna wonder why they are selling so many of those trannys soon  :tu:
Again excellent Joe- I imagine alot people will try this one.
Joe
Joe
Another update:
http://www.diystompboxes.com/analogalchemy/sch/diodepwr.html
(might have to reload the image)
Did some better parts selection, otherwise not too much different.
Brymus
Hi Joe really cool.
Are those all Radio Shack components?
That would make this really easy for anyone to build.
Joe
I tried to design a "radio-shack" amp before. It's almost possible, but would be more expensive than jusr ordering better stuff.
Quote from: Joe on September 14, 2009, 09:15:53 PM
How well are those transformers working out for you?
Joe
The transformers are working great for this, I'll be posting the complete "radio shack" power supply soon!
Brymus
I was eyeing them at RS this afternoon.
Thats really sweet idea you had using two of them at 10$ each hard to beat that price.
I am dying to hear what this amp sounds like.
Joe
Brymus
Oh thats quite a coincidence.
I just picked up those RS trannies today.I was gonna try em with my lm3886 but...
Any chance I could get one?
