Solid State Amplifiers => Preamps and Effects => Topic started by: PERFECTSOUNDFOREVER on March 08, 2010, 08:40:49 PM
Well, hello everyone, I'm a newcomer here and this is my first post.
I came here because I need a little help with my talkbox wiring. What I made for the talkbox was a simple 10W amplifier (a TDA2003) in a box, wired to a speaker and alternatively to a mono out jack for bypassing the effect (and sending the signal to a guitar amp). The thing is... I don't get any sound out of the speaker and not even INTO the circuit, so I guess I screwed up the ground connections...
Here's what I did with the wiring:
(http://img163.imageshack.us/img163/179/tda2003.jpg)
Can you tell me what have I done wrong? Couldn't found any data on the net, since all pedal effects use the same output for bypassing and I need to different outputs.
Your wiring is fine, check that the TDA works hooked to the speaker.
