Solid State Amplifiers => Amplifier Discussion => Topic started by: Blacklabel on July 22, 2007, 06:39:45 AM
Title: Fender Frontman 15G
Post by: Blacklabel on July 22, 2007, 06:39:45 AM
Hi guys,
Im new to the forum and electronics so go easy on my knowledge...Ive got a Fender frontman 15G (the cheapo verson without reverb :'( ) now i was jamming with my Boss Metal zone Mt-2 pedal, running it through my amp listening with the head phones now i cranked the level and the gain/Distortion on the pedal and was really Squealing the thing doing some harmonics and stuff and after bout 20 seconds of playing my amp just turned its self off, i turned it off and on again but nothing....i tried my amp in another power point...but still nothing, i pulled the circuit board out and had a look and the fuse seems fine and i cant see anything blown. i read the other post on the frontman amp on this site about the rectifier diodes and filter caps could be the problem so i went and purchased a Multimeter to see if i could find the problem part but i got a reading from all the parts (i dont know if you can diagnose blown parts with a multimeter but for $12 thought id try it) anyway does anyone have any ideas on what could be wrong with my amp?
and also if it is the Electric Caps...there glued in with some sort of resin how do you remove it and do i need to re-resin it if i put new ones in....if you need pix just ask ill be glad to post.
Title: Re: Fender Frontman 15G
Post by: teemuk on July 22, 2007, 07:31:04 AM
First: Before you turn the amp ON again build yourself a current limiter out of a light bulb that plugs between the amp and the main receptacle. It will prevent any further destruction.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm#tvtslbt
http://www.diyguitarist.com/PDF_Files/AmpCurrentLimiter.pdf
You've seen the previous post about Fender Frontman. You also should have the schematic so what you can basically do is to use your multimeter to measure the DC voltages marked in the test points (power supply section) You can also measure the AC voltage of the power supply. Does the power LED light up?
If you need to trace the input signal, a computer may serve as a simple signal generator (i.e. if you have cooledit or similar software you can run a loop of continuos sinewave signal at the correct frequency and amplitude). Better measure the DC offset at the input before that, though (just to make sure you don't toast your soundcard).
You can use multimeter to test if parts are faulty. You should lift the component off the circuit to get proper readings though. Diode is busted if it conducts in both directions or none at all. Capacitors will give an odd, changing reading while your multimeter charges them (yep, it does that): Basically you'll see an increasing resistance until the cap is charged when it should have nearly an infinite resistance. This measurement is pretty tricky and usually only a good capacitor tester can provide trustworthy results. If you reverse the probes the reading will get interfered again. Practically, a short circuit (very low resistance that won't increase) means the cap is busted - you might have to wait for a while. Opamps should have the stated supply rail voltages (about +-16V), both inputs in the same voltage potential and DC offset of half the supply (typically zero) at both inputs and output. I posted links to some basic troubleshooting guides maybe about a month ago - you should find the concerned thread quite fast.
If all you can say is that your amp just went mute this about the only help I can give. I was about to suggest that you should measure if the thermal fuse of the power transformer is blown but the schematic shows that it is not used so forget it. Maybe you blew the power opamp, maybe some other opamp... Quite an achievement while using headphones - considering that, I would be inclined to suspect you have blown something from the preamp stage. Better just start probing than wait for us to guess what might be wrong. It's a simple circuit.
The resin on the caps is to hold them in place so that vibration cannot destroy their solder joints (those big caps are considerably heavy and can rattle themselves loose). A sharp knife might help in removing the resin. I recommend you re-resin either with hot glue or a drop of epoxy.
Post by: Blacklabel on July 22, 2007, 09:05:18 AM
Thanks ill check a few of them things now...and as for the question..No the led does not lite up, its as it its not plugged into the mains power... i will post when i check a few of these things. thanks ;D
Post by: teemuk on July 22, 2007, 10:03:53 AM
That would indicate trouble in the power supply. You likely find something fishy in there.
Post by: Blacklabel on July 23, 2007, 04:34:39 AM
So when you say power supply, i take it its the power pack...the big silver box that the mains power runs into then it plugs in to the switch and then to the main board...if it is can i test it myself?
thanks for all your help so far :)
Post by: teemuk on July 23, 2007, 01:17:18 PM
Power supply is the circuit that converts the mains AC to suitable DC the circuit can use. That covers transformer, diode rectifier and the filtering capacitors - plus all the neccessary fuses, switches, regulators etc.
Yes. You can test it yourself - if you know how but....
...Judging by your question you are pretty much inexperienced in this field. Are you sure your up to the task of starting to repair or troubleshoot the amp yet? Understanding how the circuit operates (and what the different components are) is pretty essential for that you know. Maybe you should "do your homework" first before you pop up the hood and start probing. It might save you from a lot of agony. If you don't know what to do - and how to do - you may damage the amp further or at worst electrocute yourself.
Don't get me wrong: I don't mind helping and I understand that everyone is a beginner at some point but there seems to be an obvious limit in your skills. I just think you're not ready yet to mess with the circuit. If you really are unsure what the power supply is then you definitely need to do some research and study electronics more. Once you have a basic idea how the circuit works you may find the help you get a lot more helpful; at this point it likely just confuses you, or at worst makes you do stupid things that can harm the amp or you. I don't want to take responsibility of that. You should know your skills and whether they need improving.
Anyway, I hope you interprete these words as encouragement. Electronics is a nice hobby but just like any hobby it involves some work in order to progress and get better in it.
Post by: Blacklabel on July 24, 2007, 06:53:14 AM
Yep, no problems i see where your coming from and yes i appreciate your concern, I have done modding to Wah pedals and stuff like that but its my first time using Schematics and following circuits but i understand the principles on Circuits and how they work but im not 100% the terminology and i wouldn't work on mains power sorta stuff like power packs and that until im fully ready but like fuses and diodes, resistors and stuff like that im fine with, but as i said originally i am new to electronics and i appreciate everything your helping me with so far and i am still testing the circuits...but i have found a problem with one of the diodes..i get a reading with it both ways i test it so ill replace that one and see how i go...once again thanks foe your help so far. :)
Post by: syndromet on July 24, 2007, 09:06:56 AM
That might solve your problem
Post by: nice on July 30, 2007, 12:20:48 AM
Hi! I hope this will help you!
Schematic (http://www.fender.com/support/amp_schematics/pdfs/Frontman_15G_Schematic_68F.pdf)
:tu:
nice!
Post by: XinTX on July 30, 2007, 01:56:43 PM
Well I took a look at my deceased 15G yesterday.  The area around the power indicator LED (designated LD3 on the schematic on the left side about midway down) appears to be slightly discolored.  I used a 9V batter to apply power directly to the LED.  Tried it both directions and it still lights.  Is this correct?
The issue I have with the amp is that it blows the 500mA fuse immediately on power up.  So I'm searching for what must be a dead short.  But to date I haven't found it.
Post by: Blacklabel on August 05, 2007, 05:47:42 AM
Hey, about the led..i tested mine today, and it only lights up the one way... now i even tested the smaller 2 leds in the preamp and they are the same...hope that helps with yours
Post by: Blacklabel on August 07, 2007, 06:11:12 AM
Hi, I Replaced the 2 Main Elec Capacitiors..and the Diodes that ground straight after them....and it still wont turn on..anyone got any ideas on what might be wrong...thanks
Post by: XinTX on August 08, 2007, 01:01:58 PM
Don't know.  Mine won't turn on because it blows the 500 mA fuse about as quick as a flash bulb when I try to power it up.  I know of several of these failed Frontman 15's.  I'm convinced they're truly a POS amp.
Post by: LJ King on August 08, 2007, 01:50:49 PM
Quote from: Blacklabel on August 07, 2007, 06:11:12 AM
Remote debugging is difficult at best - even with pictures (hint).
Hopefully you used the proper zeners and not regular diodes, and installed them with proper polarity.
What voltage readings are you getting at the replaced caps?
Post by: R.G. on August 09, 2007, 12:27:19 AM
You got some good advice early on that you haven't taken yet.
You can't debug fuse blowing problems very effectively if you only get 35 milliseconds of test time before the next one blows.
QuoteFirst: Before you turn the amp ON again build yourself a current limiter out of a light bulb that plugs between the amp and the main receptacle. It will prevent any further destruction.
Go do it. There's a cleaned-up version of this at GEO (http://www.geofex.com) that is a little safer wiring as well.
But do it. That will let you quit tossing in fresh parts to wherever someone thinks you MIGHT have a problem.
There is a disciplined way to go about this.
1. Get the fuse blowing to stop so you can test voltages.
2. Test the power supply and get it running correctly, not blowing fuses
3. Remove the limiter and test individual pieces.
What you're doing in asking "Anybody know what it might be?" is asking to be told to replace a whole chain of expensive parts in hopes of eventually replacing the one or two failing ones by random luck.
Do the limiter, then get back here and we'll go to the next step. I've helped lots of people get running again with remote debugging. Maybe we can help you too.
QuoteDon't know.  Mine won't turn on because it blows the 500 mA fuse about as quick as a flash bulb when I try to power it up.  I know of several of these failed Frontman 15's.  I'm convinced they're truly a POS amp.
Well, there are several obvious design flaws I see in the schemo.
Post by: Blacklabel on August 09, 2007, 03:21:53 AM
Hi, thanks for the reply, but its not the fuse thats blown...
i was jamming with my Boss Metal zone Mt-2 pedal, running it through my amp listening with the head phones now i cranked the level and the gain/Distortion on the pedal to full, doing some harmonics and stuff while my headphones were set to about 3 on the volume in the amp and after bout 20 seconds of playing my amp just turned its self off, i turned it off and on again but nothing...no led, no volume nothing....its as if its not plugged in to the mains power, even thou it is...i tried my amp in another power point...but still nothing, i pulled the circuit board out and had a look and the fuse seems fine and i cant see anything blown. The Main power LED does not light up at all..Its not blown and neither are the 2 Smaller LEDs in the preamp stage..i think there there to stop from blowing the amp...i have replaced the 2 elec capacitors and the rectifier diodes that are linked to them..and it still wont work..i am now going to replace the 2, 220k 1 watt resistors that are linked to them also and see if that works...any suggestions please post..and i will post pix asap.
thanks
Post by: joecool85 on August 09, 2007, 07:35:14 AM
Have you checked for voltage anywhere?  It really does sound like a blown fuse.  Sometimes they will look alright but have a crack in the fuse part.  If you have voltage before the fuse and not after it, then you know its the fuse.
Post by: LJ King on August 09, 2007, 08:44:47 AM
Quote from: Blacklabel on August 09, 2007, 03:21:53 AM
and it still wont work..i am now going to replace the 2, 220k 1 watt resistors that are linked to them also and see if that works...any suggestions please post..thanks
Replacing a 220 ohm 1 watt resistor with a 220K 1 watt resistor isn't going to help much. I hope it was just a typo.
Post by: XinTX on August 09, 2007, 01:34:12 PM
Quote from: R.G. on August 09, 2007, 12:27:19 AM
Such as?
Post by: Blacklabel on August 12, 2007, 04:05:20 AM
Hi guys, i replaced the fuse..and Bingo..i have power..hahahah it didn't look blown..but it was...Thanks Joecool85...any way problems not over it now has a loud buzz sound comming from the speaker when you turn it on....and also when you turn it on the small led called LD1 lights up on the circuit board..no its not the power indicator light..its one inside..i think its a clipping light to stop blowing parts..any one got any ideas on what might be causing it..thanks
Post by: teemuk on August 12, 2007, 04:22:13 AM
If it buzzes then usually the first thing to do is to check the condition of filter capacitors (and their solder joints). These are C29, C30, C31 and C32. LD1 is one of the diode clippers for the drive channel - it doesn't stop parts from blowing up, just adds distortion by limiting the signal amplitude by clipping the signal tops off. In this case it clips off the top of the buzz signal.
Post by: Blacklabel on August 12, 2007, 05:00:26 AM
hi, thanks for all you help everyone but now its just blowing fuses :'(..so ive given up on it :trouble..ill use the case and pots and speaker for another project...and i suggest every one bypasses the fender frontman series when buying an amp....too much trouble..but i thank every one who has helped me out....
Post by: XinTX on August 13, 2007, 07:07:02 AM
Quote from: Blacklabel on August 12, 2007, 05:00:26 AM
My problem as well.  Just blows fuses.  Mine blows them instantly, so I can't even probe to check voltages in the circuit (the only diagnostic on the schematic).  Agree the Frontman series are total garbage.  I'd also advise folks to avoid them.  And I'm going to use the cab and speaker for my own project.
Post by: R.G. on August 16, 2007, 08:12:08 PM
Quote from: XinTX on August 09, 2007, 01:34:12 PM
Such as?
1. It perpetuates the Fender Mistake of using 15V zeners to power opamps. CR11-12 should be replaced with 7815/7915 regulators and R48-49 lowered to 150R 1W.
2. I can't find any local decoupling for U4
3. No local decoupling for opamps
4. board-mounted pots and jacks
Those are the ones that come to mind immediately.
Post by: R.G. on August 16, 2007, 08:13:40 PM
Quote
Post by: Blacklabel on November 21, 2007, 08:13:55 PM
thanks all for your help its ok tha dead amp still doesent work so ill us it for a project later on down the track...im now the prowd owner of a Marshall Valvestate VS100R Combo, so once again thanks for all you help.
BLACKlabel :)
Post by: Brian Ward on January 28, 2016, 05:16:20 PM
I know this is an old topic and It's quite possible that someone else has started a new one somewhere. I stumbled onto this one while looking for parts for  one of these Fender Frontman 15G amplifiers. I thought it might be useful for someone else who is having problems with this amplifier blowing fuses.
#1 - Do not defeat the fuse. It is there to protect you, the wiring, and other components in the amplifier. If you defeat it you will be looking for a hard to find transformer that is out of production. 16.4V on the secondary (output to the amplifier)
#2 Replacing random parts is a huge waste of money and time. As someone else has already stated earlier in this thread there is a process for diagnosing repairs. Always check the fuse first. Just because it appears good doesn't mean that it isn't blown. Use a multi-meter and test for continuity.
Okay, now that I got that out of they way. It is helpful to do a little homework before you begin any work for a products known issues. It can save you a lot of time and often someone else has already repaired the item many times and shared their knowledge. I found this to be the case with the Frontman 15G and other similar amplifiers.
Yes, many of you are right in your assumptions that the amplifiers are junk. They are poorly designed and have problems. Let's be honest here. Not too many of you are building amplifiers. It's pretty easy to say it's junk when you've had problems with it, but in honesty it can be a decent little practice amp for a great many people when treated kindly.
The most common failure with the amp is when using the headphone jacks or the external input from another device. The J-fet will fail and can often damage some parts around it. These are fairly cheap to buy by most standards and are easy to replace. Adding an external heat sink above and beyond the one Fender supplied with the amp can also extend this transistors life a great deal. Keeping the drive moderate (This includes using pedals at a reasonable level) will also go a long way to keep it running.
Who doesn't like distortion? I know it's all part of the fun and often part of the sound. Distortion damages speakers quicker than anything else. Keep this in mind when you've got it squealing and howling.
So, let's begin diagnosis. You should have already checked the fuse. If the fuse tests good you're headed in the right direction. If it doesn't replace it and sometimes you get lucky and you're back in business.
Fuse blows immediately? Well, that means you need to find out what is causing an overload condition. Something is drawing too much power (Likely that main power transistor / JFET that Fender put into the amplifier.  Replacing the fuse again at this point is a waste of time. Meter the secondary on the main power transformer and see what the voltage is.
The Fender Frontman 15G should be between 12 - 18 volts. The transformer I have is rated at 16.4V. If you've got some voltage that's larger or smaller your amp likely won't work. You're going to be searching for that transformer for a while.
Transformer seems okay? Check the input voltage at the JFET and also the output voltages. Nothing huh? Replace the JFET it's a TDA2030 for the 15w or a TDA2050 for the 30w version. Replace it with one that matches your model.
Likely this will have your amp up and running.
As for buzzing in the amplifier. This is usually a grounding issue on the signal path. it can also be caused by poorly done solder work. Make sure that when you solder things that you use a heat sink and do not make cold solders. Check that there is no solder paths being made where you don't want them and always check your work before you apply any power.
Post by: Katoda on January 29, 2016, 11:48:05 AM
Most likely the TDA2030 burnt out. I had the same problem, instead of replacing the chip, I took all the guts out and built in some valve stuff  8)
Post by: J M Fahey on January 29, 2016, 08:49:34 PM
Weird post with a few inaccuracies strong enough to merit correction:
Quote from: Brian Ward on January 28, 2016, 05:16:20 PM
QuoteYes, many of you are right in your assumptions that the amplifiers are junk. They are poorly designed and have problems. Let's be honest here.
You did not read that in this Forum .
QuoteNot too many of you are building amplifiers.
Again you refer to some other Forum.
Quote
Again .....
Quote
Which J-Fet ?
Quotecan also extend this transistors life a great deal.
Which transistors?
Quotethat main power transistor / JFET that Fender put into the amplifier.
Which transistor/JFET?
QuoteReplacing the fuse again at this point is a waste of time. Meter the secondary on the main power transformer and see what the voltage is.
Well, this one is easy: 0 Volts.
What you will always measure if you don't replace the fuse.
QuoteCheck the input voltage at the JFET and also the output voltages. Nothing huh?
No input voltage: means amp OFF (or lack of fuse or fuse blown open).
No output voltage: means nothing if it's not receiving any power to begin with.
Anyway your test might be approppriate for a 3 leg Voltage Regulator.
Since we have a 5 pin power amp I'm not sure about the test as described.
Quote
Oh, those, you mean the chipamps?
