Quote from: stratitis on April 25, 2020, 02:15:52 PM
Can somebody help me finding "Roland Blues Cube Hot" schematic?
I'm thinking it unlikely you'll find this schematic, I've not seen it, that's for sure. Are you repairing one, or looking to make a clone?
I want to analyze the schematics to understand the Roland "Tube Logic" technology.
I randomly found an used equipment offer of that amp (i never heard of it before) but the reviews I found were not too bad...
https://www.soundonsound.com/reviews/roland-blues-cube-hot-british-el84-modified
https://translate.google.de/translate?hl=de&tab=wT&sl=auto&tl=en&u=https%3A%2F%2Fwww.bonedo.de%2Fartikel%2Feinzelansicht%2Froland-blues-cube-hot-test.html
Quote from: Jazz P Bass on April 27, 2020, 07:42:45 PM
"Tube Logic – a marriage of solid-state analog technology and DSP"
Not too sure how the schematic will reveal the true nature.
Sounds like they're running an analog opamp into a DSP circuit lol.
Obviously there are DSP (about 2014) and non-DSP versions (about 1996)
I'm interested in the non-DSP.
(user manual BC-30: https://static.roland.com/assets/media/pdf/BC-30_30-210_OM.pdf )
"This Vox-inspired special edition of Roland's analogue modelling amp is equally impressive at home, on stage or in the studio." [edit: this is a DSP version] ( https://www.soundonsound.com/reviews/roland-blues-cube-hot-british-el84-modified ).
That's what I've found:
https://www.vguitarforums.com/smf/index.php?topic=11865.0
There's a schematic of the Blues Cube 30 (no DSP, no reverb, no USB, no power control switch):
Better quality service manual (including schematics):
http://www.synfo.nl/servicemanuals/Roland/BC-30_BC-60_SERVICE_NOTES.pdf
Power amplifier uPC1188H:
http://www.electronica.ro/audio/uPC1188H.shtml
https://translate.google.com/translate?hl=de&sl=ru&tl=en&u=http%3A%2F%2Fradiostorage.net%2F3404-mikroskhema-upc1188h-usilitel-nizkoj-chastoty-18watt-pri-22v.html
Q1,2,8,9,10,11 (amplifier stages):
2SK184, N channel J-FET
https://alltransistors.com/pdfdatasheet_toshiba/2sk184.pdf
Q3,6,7,13,14, 19(?) (signal switches, tone stack output impedance converter):
2SK246, N channel J-FET
https://alltransistors.com/pdfdatasheet_toshiba/2sk246.pdf
Q15,16 (tone stack driver):
2SK363, N channel J-FET
https://alltransistors.com/pdfdatasheet_toshiba/2sk363.pdf
