Solid State Amplifiers => Tubes and Hybrids => Topic started by: rhythm player on August 26, 2009, 01:30:55 PM
I have a VOX AD50VT that suddenly stopped working. Everything was fine at a friends house but when I took the amp home and turned it on it had a terrible hum. None of the controls have any effect on the noise. This amp has 1 12ax7 pre-amp tube so I swapped it with a known good one but that had no effect either. Before I tear into this thing does anyone have any suggestions on what the problem may be?
Quote from: rhythm player on August 26, 2009, 01:30:55 PM
Sounds like an issue with your poweramp to me, not sure what though, but I'm guessing maybe a blown cap somewhere.
Thanks for the reply. I have checked everything I know how to check and can not identify the problem. I guess I will have to take it to the shop.
You can email support@korgusa.com and request a wiring diagram if you are familiar with working on electronics just let them know it is out of warranty if it is. or go to http://www.korg.com/DealerLocator.aspx?type=service (http://www.korg.com/DealerLocator.aspx?type=service) for a service center.
