April 25, 2024, 05:52:18 AM
Sunn Dymos
Started by gbono, June 06, 2020, 07:02:30 PM
gbono
I have a Sunn Dymos with all the output/driver/reverb transistors removed. Looking at the schematic, it looks like these transistor's collectors (they are all TO-3 2N3055) should be isolated from the chassis - is that correct? Point A and B on the schematic would be grounded without isolation but i don't have any mounting hardware with this chassis to verify how the collectors should be connected.
The jpeg is off the net for reference only.
They appear to be mounted in your photo.
gbono
Yes the image shows the hardware mounted but that's not what I have on the bench it's an image off the web. What happens if points A and B are connected to chassis ground -i.e.  the collectors are not isolated?
duckduckgoose
all of those old sunn's look awesome  :dbtu:
You need mica spacers (& thermal paste) for the TO-3 transistors, and insulating bushings for their mounting screws.
Quote from: gbono on June 07, 2020, 04:22:22 PM
I think you are missing something about how the circuit works and is confusing your question.
Point A is the supply for the collector (NOT GROUND)
Look at the bottom of Schem and find the rectifier D101
You will See that point A is the Positive supply for the collector (pointA)
The *Emitter* of the lower transistor is Point B
That is the Negative supply shown at bottom of D101.
Those 2 points DO NOT connect to ground.
To add even more confusion
This is an odd circuit and someone here with better understanding may know more.
note the speaker neg returns to neg voltage rail????
So it makes no sense to me.  :loco xP
hope it helps, Phil.
Points A and B are power supplies.  If you do not insulate the transistors from the grounded heat sink, it will short out the power supply, and blow fuses the instant you turn it on.
Think of this as a single supply, like a bunch of old Acoustics.  The output would sit half way up the power supply with a big cap to block DC.  On this they didn't reference the speaker to ground because the "ground" is now V-.  But same deal.  Just cannot allow speaker jacks or cables to touch ground.
Quote from: Enzo on June 07, 2020, 09:22:54 PM
This is truly bizarre as shown if correct.  The output of the bridge rectifier is +35/-15 ?  So the power amp output sits at +10V ?
Looks that way to me.  I hadn't paid that close attention.  The -16v rail comes right off the bridge, while the +16 comes through dropping resistors.
SO just like the one supply Acoustics, this thing is powered between A and B, and it really doesn't matter at all where on the spectrum that sits.  If we call A to B the supply voltage, the speaker will be drawing from 1/2 of that and B.
Kinda clever really, they have a 50v supply, split offcenter.  And only one of the low voltage rails needs dropping resistors.
gbono
So if I should see +15V across C105 and -15V across C104? Supply voltages not referenced to chassis ground.
Main rails not referenced to ground, but 15v rails are.
Still a little surprised at this one, but I thought B+ will read +34V with respect to chassis ground.
What else can it be referenced too?
Probably will.   Whole 50v supply referenced to ground through the -16v supply.
gbono
#13
I'm having a problem with the supply voltages. If I measure across the bridge (A-B) I get +2VDC. How do I verify supply voltages?
Okay just saw your post - still only get 2VDC from B to chassis ground. 40VRMS into bridge. Bad bridge?
40v AC?  Turn the thing off, and measure resistance of that 40v winding - just to be sure.  An open winding can still induce voltage into your meter.
Bad bridge?  A bridge is nothing more than four diodes in a single package, get out your meter and test it.
