Solid State Amplifiers => Amplifier Discussion => Topic started by: el nino on July 22, 2012, 05:55:23 PM
hi guys, i'm planing to build an ESP Project 27 power amp, can i power it with DC -+25volt and 2 ampere trafo? How much watt power can i got from it? Thank's
You'll get around 40W into 4 ohms.
thank you sir, i found this layout from google...
Can i use it? Or its need some mod?
It's very kind if you check it, if you dont mind... Thank's again sir
Really don't know, ask Rod Elliott himself.
Obviously the origiunal PCB works without problems and probably comes with assembly instructions.
