Laney VC30 Output Transformer
Started by ilyaa, December 12, 2019, 01:06:25 AM
ilyaa
if you were replacing a blown OT in this 30 Watt, 4xEl84 amp, which one would you get?
https://www.mojotone.com/amp-parts/Output-Transformers/Black-Brown-Vibrolux-Tremolux-Output-Transformer-4-8-OHM
or
http://www.triodeelectronics.com/22bastou.html
(not sure if they have that one - i e-mailed em)
or
https://www.mojotone.com/amp-parts/Output-Transformers/GA30RV-RVH-Output-Transformer
or
any other suggestions?
part of my issue is the stock transformer thats in the amp is very small - its snuggled between the second preamp 12ax7 and the PI - would like to find something small so i dont have to destroy the chassis putting the new one in.....
thank you!
The links are mostly for 6V6, you need a Tx for EL84.
IIRC a quad of EL84 needs a primary winding plate to plate of 4k.  Pri Z is usually just written as (4k pp) on data sheets.
Others here might know places in your location to find a Tx that will work well for that amp.
1760J looks like it would be close.
Generally a pair of 6V6 use ~6k pp
while a pair of EL84 would be ~8k pp
The reality is,
there are many OT parameters that effect the final outcome.
Phil
