February 12, 2025, 07:17:57 PM
Filtering frequency revisited
Started by saturated, January 01, 2025, 10:09:17 PM
saturated
Made another go at this since I worked a few chapters in my text book
Wiring this old artifact ballast in series with a 1000 ohm resistor and putting variable frequency through it.  With predictable results  :tu:
So now when people see me wandering around wondering what I'm thinking about it's gonna be....."so the resistance of the inductor (ballast) goes up..... :lmao:
I ask stupid questions
and make stupid mistakes
saturated
I remembered I had a monster choke so I went and grabbed it and repeated the tests
:loco
The results were not what I expected it is such a beast I figured it would have crazy reactance a lower frequency
But it let me go much higher
 xP
I have a lot to 💬 ponder  :'(
saturated
Btw I used an atlas lcr45 on the ballast it measured about 755 mH
So on the label on the monster choke I guess hys means Henrys then it's 5 mH  :loco
I have very small 10 and 15 mH inductors so why is a 5 mH so big and heavy 🪨  :grr
Edit: because it can handle 22.5 amps and 1500 volts
saturated
So then I'm doing a bunch of problems where the output voltage ⚡ is divided by the input voltage at different frequencies and do some more calculations with logarithms etc and it gives me the frequency response (?).....in decibels...?
I thought decibels was like dude how loud 🔊📢 is stuff.  Like a 70s Who concert or 707 taking off.
Oh well back to the grind  xP
saturated
I'm doing lots of the same stuff over and over with resistors capacitaters and inductors  :tu:
I've been impressed with this hobby that experimental results closely match calculations.
However I'm wondering if there is a limit to how accurately my multimeter can measure ac voltage ⚡ drops (rms) at different frequencies....like 20 khz
Oh well I guess that's why we have oscilloscopes (Vp-p)
Or bench multimeters ?  xP
I'm sure it would be cool 😎 to have a bench meter but I certainly don't need voltage to twenty decimal places or a real earth ground (thanks G1  :tu: )
Your meter should have a spec for the AC volts range as far as frequency response.
My true RMS meter says 45Hz to 2Khz.  A lot of them are just for measuring AC volts in the 60 to 100Hz area.
Yes, scope is best bet for higher freqs.
saturated
Here is an 🥼🧪 experiment I just did
I was really impressed how the measured hung right in there with the calculated
Unfortunately at 50 khz it went out the window
Here is the "schematic"  :lmao:
I know
I should have remeasured everything with my scope.   :grr
saturated
Ok I went and redid the experiment this time using my scope to measure the voltage drop across the resistor at different frequencies and got some good results  :tu:
(bottom left)
gratuitous scope pic
 xP
So all I need now is a gif of Keanu going
"DUDE.....your meter can't handle it "
 :loco
saturated
Well I got into somewhat of a pickle 🥒
I have three chapters to go in my little book before I can go on to the cool second book that has me playing with transistors and diodes and stuff but I hit a 🛣� roadblock.
The third from the last chapter was on bandpass filters so I ran into trouble with the impedance calculations of inductors and capacitaters and resistors in parallel.  Meanwhile I was like "what is all this j and theta crap"  :grr
I tried to get through it but ultimately admitted defeat and went back to a chapter in a book a did a few years ago so I'm midway through that.
So all good it should be rewarding to get to the lab portion and see 🙈 how the 🥼 experimental 🧪 results compare.
There is a post by one of our esteemed members from near Australia 🦘 🌏 where he told someone what frequency to expect from a potentiometer and capacitater  xP so I may play around and see if I can figure out how he calculated that  :loco  :tu:
saturated
Ok I tried it  :loco
I got lucky I guess  :lmao:
Might be time to buy a lottery ticket  xP
saturated
I'm glad you were nice
I actually got scared when I saw you replied  <3)
 :lmao:
saturated
About forty years ago when I was still in college and working part time the university had afternoon/evening classes I guess it was geared towards working older people  xP
So anyway I was a 🦇 vampire staying up all night doing homework and playing guitar 🎸 etc and my routine had me going to bed 🛏� at about 0530.  I had found that Casper the friendly ghost 👻 came on like at 0500 and that was my SOP.
So what does all that have to do with anything?  :loco
At night in the small town it got quiet with the exception of an audible hum  :grr
Sometimes I would have the windows open I was in an upstairs room at the end of the house.  This (real or perceived) hum/pitch/monotone frequency tormented me to some end.  In fact I made a few nocturnal excursions around town looking for it.  I would drive around to different areas and shut the engine (slant six 66 Dart) off and sit and try to determine where it was coming from.
Spoiler alert: I never did find it or find out anything.
When I told my dad about it he said there was a composer that went crazy because of constantly hearing 440 or something  :trouble
xP
Quote from: saturated on February 02, 2025, 05:43:03 AMAbout forty years ago when I was still in college and working part time the university had afternoon/evening classes I guess it was geared towards working older people  xP
xP
Was there a hydro-electric power plant nearby at all?  Or did the college have a steam plant?  They create hum like you are describing.  UMaine Orono has a steam plant, and a lot of northern colleges do.  Not sure about out your way.
